12-13-2018 10:30 PM
I bought this multifunction office printer recently, and I love it except that there is only one available scan resoution available, 300 dpi) when I scan to my Mac Book Pro running Mac OS 10.13.6.
Attached is a screen shot
As the image shows, only the 300 dpi option is available in the resoution menu. This causes the scanned file size to be quite large for multi page documents.
Any suggestions?
12-17-2018 03:49 PM
Open up a copy of the scanner's User Guide at the link below...
http://gdlp01.c-wss.com/gds/3/0300029863/04/mac-scan-v2130-ug-en.pdf
Start out at page 32 and pay particular attention to page 35. I think having your output format set to PDF has locked you into some settings that you'd want for a higher quality scan and assuming that you may not know how to adjust some of these settings yourself.
I suspect that by choosing "Custom" as your output format you'll be be able to choose the scanning resolution you desire and you'll probably be able save this custom scanning profile for later use. It may unlock some other scanning parameters as well.
12-19-2018 11:53 AM
Hi doctorfork.
I will be glad to assist you.
It looks like you are using the Mac Image Capture program. Please open the MF Scan Utility from Launchpad, and then click ScanGear. The ScanGear MF window will open:
Click the Advanced Mode tab, and then you will be able to select up to 600 dpi using the platen glass.
If you have any further questions, or need any additional assistance, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
