Can not scan MF624CW
Henry2000
HI, My MF624CW was doing fine but lately the scan utility had some issues. So I reinstalled the latest printer driver and the scan utility. Now the printer can print, but  scan utility gives error message saying there is no printer driver. Interesting thing is that my wife's computer can still scan. Can someone help? Thanks,
Assuming this is a software problem, please run this and re-test scanning:
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAwNjg0MTA1&cmp=ABR&lang=EN
If you are prompted to make changes to the windows firewall, say yes.
If it doesn't help, let me know. 😀
5 REPLIES 5
Stephen
Moderator
Moderator
Hello!
So that the Community can help you better, we will need to know more information:
• What is the exact error message?
• Which version of Windows or macOS are you using?
• How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please call support at 1-800-OK-CANON (800-652-2666), Monday through Friday.
If you're outside the USA, please click HERE to find support options in your country.
Thanks, and have a great day!
Henry2000
Window 11, connect to this MF624CW with wifi
error message when I invoke MF scan utility:
a scanner driver supporting this software is not installed. Install it and try it again.
I have installed winmfscanutilityv12102. The printer driver is UFRIILT_Driver_V3088_64. I can print to this MF624CW printer, but can not scan.
Thanks,
Your suggestion solved my problem. Really appreciate your help!
Glad it helped.  Thanks for the feedback.
Holiday
