06-08-2015 06:15 PM - edited 06-08-2015 06:19 PM
I set up access to the Canon Remote UI Management Mode (Portal) using my IPv4 address so that I could make changes to the settings of my imageCLASS MF6160dw directly from my Desktop Computer.
That has worked flawlessly for almost 3 months.
Then, all of a sudden 3 days ago, I started getting this message: This page can't be displayed
I have not added nor removed any equipment or software to my Desktop Computer.
I also reconfirmed that my IPv4 address was correct.
And I try to access the "Portal" numerous times at different times of the day & on different days.
My Desktop Computer is a Dell XPS 8700 Special Edition running Windows Pro 8.1 (64-BIT)
How can I regain access to the "Portal"?
06-29-2015 03:04 PM
06-29-2015 03:04 PM
01-08-2019 01:47 PM - edited 01-08-2019 01:49 PM
That is part of your problem. Your copier should be a fixed IP address. If you can't access the UI by name or by name from your printer settings.
If you have a small company place all your printers starting at .100
You can to this in the copier under network settings or do it at your DHCP server (wherever that is located for you)
01-15-2026 12:21 PM
Good Morning - I can nopt access Remote UI from the browser ERROR "This site can't be reached". I loaded yesterdAY, but wouldn't let me login. Today it won't load at all.
I checked my IP Address and unlike Steven1, my IP Address has not changed.
I could really use some help.
I have a Canon IMAGECLASS MF665Cdw.
I appreciate your time.
