05-28-2016 12:37 PM
(a) My new 6400 turns itself off automatically after being used for a while. I do not want it to do this. I have searched for the option that controls this, but I can't find it. Can someone tell me where to find this option?
(b) If I send a print job to the 6400 when it is off, the job does not print. More importantly, I cannot then cancel that job. In my Windows 8.0 print manager, the job just sits there saying it is deleting but nothing happens. How can I resolve this problem without restarting my computer?
Thanks in advance,
Mike
05-30-2016 01:04 PM
Hello.
The iPF6400 has an automatic Shut Down Timer. By default this is set to 8 hours. Perform the following to turn the timer off:
1. Press Menu.
2. Select the Set./Adj. Menu.
3. Choose System Setup.
4. Choose Shut Down Timer.
5. Turn the setting off.
Once this has been done, use the back button to back out of these menus and return to the home screen.
Typically, cancelling the job should remove it from queue. If this is not happening on your particular computer we would have to advise that you restart the machine. Once you disable the Shut Down Timer you may not have to perform this again.
05-28-2016 03:54 PM
I'm not familiar with that printer, but do you have a page like this in your printer driver?
05-28-2016 04:00 PM
See this:
05-28-2016 04:26 PM
Hi J,
Thank you very much for your contribution. Unfortunately I cannot find anything like the power off option shown in your image. My maintenance window has only printhead/cleaning options.
But thanks for trying.
I found that when I got out of PS CC, my printing block disappeared and I have now printed. But I would still like to figure out the power off option.
Mike
05-28-2016 05:40 PM
Hi Mike.
My second post was a scrteen shot of the manual I googled. Check your manual for system setup window.
05-29-2016 11:00 AM
Hi John,
Your input was helpful as it directed me toward a search of the manuals. After some thrashing around, I found the answer in the Basic Guide.
Keep in mind that the menu structure of your P100 is not the same as the one for all other Canon printers. But thanks for prompting me to do an online search of the manuals.
Mike
05-30-2016 01:04 PM
Hello.
1. Press Menu.
