07-25-2022 09:59 PM - last edited on 07-26-2022 08:55 AM by Danny
I am trying to print from my new windows 11 dell laptop using the USB cable from printer to laptop. My computer does not give me the option of choosing the iP100 and I can not add this printer.
Any suggestions?
07-26-2022 05:11 AM - edited 07-27-2022 12:00 AM
@sohker wrote:I am trying to print from my new windows 11 dell laptop using the USB cable from printer to laptop. My computer does not give me the option of choosing the iP100 and I can not add this printer.
Any suggestions? Target Gift Card Balance
Hello Sohker,
I was same issue last time but now My issue is solve I think this is work for your error you must see this : https://support.usa.canon.com/kb/index?page=content&id=ART151074
07-26-2022 09:49 AM
Thank you but I want to use the USB connection. I do not have Bluetooth for this printer.
any other suggestions welcomed.
07-26-2022 11:56 AM
When you install the Canon printer driver, is the printer not detecting during the printer setup?
07-26-2022 12:14 PM
Did not install printer driver, how do I do that? Where exactly do I find the print driver?
07-27-2022 01:14 PM
Please click HERE to open the support page for you printer. This page will contain the driver for your IP100.
07-27-2022 09:40 PM
I clicked on your link to drivers and downloads. One driver shows up iP100 series Printer Driver Ver. 2.17b (Windows 10 x64/8.1 x64/8 x64/7 x64/Vista64). Do I download this? I have windows 11? There are no drivers under windows 11.
thx
08-03-2022 11:42 PM
To Arthur J
I never received a response can you answer my question above? I clicked on your link to drivers and downloads. One driver shows up iP100 series Printer Driver Ver. 2.17b (Windows 10 x64/8.1 x64/8 x64/7 x64/Vista64). Do I download this? I have windows 11? There are no drivers under windows 11.
10-19-2023 09:23 PM
At this time, Canon iP100 Series doesn't have a driver for Windows 11. To connect your iP100 Series printer to your Windows 11 computer:
(1) Plug in your iP100 series printer to your computer and turn on your printer & computer. (2) Hit the (4 squares) Windows button. (3) Go to "Settings". (4) Select "Printers & scanners". (5) Go to "Add a printer or scanner" and hit the blue "Add device" button. (6) Go to "The printer that I wanted isn't listed" menu and hit the "Add manually" button. (7) Choose the "Add a local printer or network printer with manual settings" then hit the "Next" button. (8) Go to the "Use an existing port" drop down menu & find your printer, then hit the "Next" button. (9) Choose your printer from the "Manufacturer" & "Printers" list, then hit the "Next" button. (9A) HOWEVER, IF YOU DON'T SEE YOUR PRINTER ON THE LIST, hit the "Windows Update" button & allow the system to refresh your menu. You should see your printer. Then you can follow step (9). (10) The system should then recognize your printer. You can print a test sheet to make sure. Follow any remaining prompts, and you should be set!
03-01-2023 06:42 PM
Will the Pixma iP100 work at all with Windows 11? One chart I saw showed no Canon printers working with Windows 11. I've spent hours trying to get the iP100 to work with Asus Windows 11 and am running out of trial advice.
Anybody know what's going on?
