05-18-2023 10:35 PM
I just started using my Ivy2 printer. I’ve tried the border settings out and every time I print, it cuts off the bottom border.
What am I doing wrong?
01-12-2026 04:33 PM
This seems to still be an issue, any update on resolutions? I am trying to print out book covers, and it is cutting off the bottom of the cover that has the author name.Author name cut off on bottom
01-23-2026 10:26 AM
Hi lexnichole! Thanks for contributing to the Canon community. I see that the bottom of your prints are being cut off.
So we can offer a solution, can you please write back with answers to the following questions:
If you need a solution quick, I recommend creating a My Canon account, registering the printer, and seeing if you have the option to call our toll free support number (1-800-652-2666). You can create your My Canon Account by clicking on "Don't have an account" at the following website:
https://myid.canon/canonid/#/login
I look forward to your response. Thanks again.
01-23-2026 07:29 PM
You can’t offer a solution. Canon says it’s a universal issue with the Ivy 2.
Go back a read this thread. I use the Ivy 2 with the Canon Ivy app. There are no options for settings. And I use an iPhone. It doesn’t matter because it’s a problem on Canon’s end. We’ve complained and it’s never been dealt with. I just don’t use that printer anymore because it’s terrible.
02-10-2026 10:14 AM
Hi thanks for your response, but shortly after posting this I called customer support and was told this was already a known issue with no resolution at this time, which is a bit disheartening to hear because I received this as a birthday present. But in case you still need the info:
- yes I am using the canon ivy 2
- I am using the canon mini print app
- I’m going to attach which setting I’m using
- and now along with this issue, it’s printing out the bottom two shorter than the top two.
- I am using the iOS app
