10-27-2014 08:47 AM
Guess I'm a dummy. Can't find anything that says that. ;-((
10-27-2014 09:00 AM
Hi, samintx!
Each reply in any forum thread should have a red box-shaped button labeled "ACCEPT AS SOLUTION," including this one. You'll see it in the lower right of each individual post, beneath the REPLY and QUICK REPLY buttons.
We hope this helps!
10-27-2014 09:22 AM
Your message had the quick reply in red by the message I got from someone else nada...I keep going bac to it and no Quick reply button underneath the "reply" for some reason
10-27-2014 09:30 AM
Hi, samintx!
The "Accept As Solution" option just allows other users who might be browsing through to see which solution worked for you. It's a courtesy to future users, though not a hard requirement. If the button isn't there, don't sweat it. What matters is that your problem was, in fact, solved.
Thanks again for using the Canon forum!
10-27-2014 10:35 AM
@samintx wrote:Guess I'm a dummy. Can't find anything that says that. ;-((
I believe it's visible only to the original author of the thread.
