03-03-2016 07:14 PM
OK So I am wondering if I need a Canon printer to print pictures from a Canon EOS camera using Sd card straight from the camera to the printer. Yes I will be shooting in RAW.
03-04-2016 05:33 AM
If you have a PictBridge compatible camera and printer it will work. Doesn't have to be a Canon PictBridge printer.
03-04-2016 08:01 AM
Yes. Read your manual.
03-04-2016 05:33 AM
03-04-2016 05:49 AM
However will any printer be able to read the propriety info in the canon raw file?
03-04-2016 05:54 AM
If you are following the instructions for PictBridge the camera does the RAW conversion. But you need a PictBridge compatible printer.
03-04-2016 06:21 AM
ok I got a canon 6d and t3i and a pictbridge compatible epson xp 620 do I need a cable?
03-04-2016 08:01 AM
03-04-2016 07:24 PM
You sir deserve a Kudos!!!!!!!!!
