03-23-2025
04:38 PM
09:07 AM
Hello I ordered a canon camera , I received the email that says thank you for your order, with my order number first it says preparing then it says processing , but it’s been stuck on processing.
03-23-2025 04:59 PM
For privacy, please remove your personal information from your post. 🙂
03-23-2025 04:59 PM
03-23-2025 05:15 PM - edited 03-23-2025 05:38 PM
All PS cameras (the ones you can still get) have been on back order on and off for more than a year. You'll eventually get yours but it could take a while.
The PowerShot V1 is going to be announced on the 26th and should be generally available in April. It's going to be $100 more than the g7x mkIII. I'd probably order one and see which got fulfilled first 😄. The g7x. Mark III is going to be a little bit smaller. It also won't have the same video capabilities.
Still photography wise the sensor in the V1 Is going to have much better low light performance. By better I mean dramatically better.
Better battery life, Fully articulating screen versus tilt only, and much more. Take a look at the side-by-side comparison below. For a hundred bucks more, it's worth consideration. You'll also know when it's going to be in your hands after you order versus "processing".
03-23-2025 05:27 PM
From DP Review
