01-05-2020 01:25 PM
I need a link to this file: cnmnpu.exe. Please do NOT tell me to look on installation disk. Obvioulsy if I had it I wouldn't be asking the question.
01-15-2020 03:23 PM
I have a CNMNPUT.exe but it is inoperable. Date created 8/30/12.
01-15-2020 03:25 PM
01-15-2020 03:28 PM
Yes. Does not work. See post directly above yours.
01-15-2020 03:33 PM
Do not move the file outside of the folder that it is in before running it.
01-15-2020 04:09 PM - edited 01-15-2020 04:10 PM
Thank you. Found it.
Please leave this up. There are other people who need this solution as I saw many posts about the same subject.
03-15-2020 05:31 PM
I have a MF741Cdw and I couln't find the cnmnpu.exe file. The driver's folder extracted is MF741CMFDriverV6401W64
03-16-2020 08:34 AM
Hello oopseedo,
If you've followed the instructions in this thread and you still need assistance, we recommend reaching out to support.
Click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find your support options.
08-14-2020 04:23 PM
I too need this file, or at least a solution for my MF644cdw. When I try to run the driver installation software from the optical disk it fails because it cannot create a port. Best solution I can find from others with the same problem is to run this file to remove printer ports. This is a refurbished computer and may have had other printers installed in the past.
This is extremely frustrating that I cannot use my $400 laser printer because of a basic software conflict. I really thought the Canon software would be written well enough to fix this issue itself. Please help.
08-20-2020 01:11 PM
Hi sweso82.
For imageCLASS models, the process may be different. If you're located in the U.S., our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
If you're located outside of the U.S., you may find your branch of Canon through the map at https://global.canon/en/support.
