05-03-2017 02:27 AM - edited 05-03-2017 02:49 AM
I have canon 750D, I want a nice sharp/clear image of my jewelry, do I need to invest in macro or buy new camera.
Thanks
05-08-2017 10:16 AM
"Not legally."
Then don't do it. ![]()
05-08-2017 10:36 AM
For focus stacking do I need to use continuous light or flash?
Thanks
05-08-2017 10:43 AM - edited 05-08-2017 10:43 AM
Either but you do need proper exposures. You do need a post editor like Lightromm or Photoshop. There are others but these two are the best, IMHO. You can google 'focus stacking' and get some good hits.
Basically what you do is get different parts of the subject in focus not worrying about the rest that isn't. The stacking software picks and chooses the sharpest parts of all the shots and 'stacks' them into one photo.
Lo and behold everything is sharp! ![]()
05-22-2017 04:35 AM
This is the result now with f/11 focus stacking (maybe not perfect, just testing). tripod with 2 secs delay, w/ 2 flash. kit lens 18-55mm, still in raw files.
any more suggestion to get the clarity of the diamond, I already tried to change the position of the flash.
Thanks
05-22-2017 05:13 AM
Nice!
Did you get or do you have Lightroom? If you do you might try to add some 'Clarity' to the shot. It is a slider setting in LR. Do it after you do the focus stacking but don't go overboard. Less is more!
05-22-2017 05:18 AM
my boss needs more clarity in diamond for brochure, should i experiment more on light or do I badly need a macro lens to get that clarity.
Thanks
05-22-2017 05:18 AM
A little Clarity added to your shot in LR.
05-22-2017 05:22 AM
That is still your photo with just some post editing done in LR. I upped the Clarity slider to about 50.
Of course a better dedicated macro lens is going to produce better shots. How much better and whether it is worth it, is up to you but macro lenses are tuned to do just this type of work.
05-22-2017 05:27 AM - edited 05-22-2017 05:28 AM
How can I fix this white balance thing, I tried looking online but I only got this fix.\
The diamond is very dull looking.
He needs more something close to this one. with my current technique and setup. I know I cannot achieve like that one, but maybe close to that for brochure. I know this is retouched.
05-22-2017 05:52 AM - edited 05-22-2017 05:53 AM
Do you mean you want the BG to be perfect white?
