04-27-2015 12:15 AM - edited 04-27-2015 12:22 AM
I've tried troubleshooting multiple times:
- Uninstalled and reinstalled drivers
- Returned and bought same model scanner
- Tried different drivers
- Tried different USB ports
My computer build is:
Intel i7 4770k
16GB 1866MHz RAM
Asus Maximus Impact VI
nVidia GTX 780
Corsair RM550
Windows 8.1 64bit
I don't know what I'm doing wrong. Anyone else get this? It's making me quite livid just trouble shooting it. I've read a lot of reviews on this on Amazon and other websites that says that this is plug and play for the most part. What am I doing wrong??
02-12-2017 10:25 PM
I just bought the CanoScanLide 120 and I have Windows 10. I have found the solution for Canon LiDE 120 error message: "Cannot communicate with scanner for these reasons:" Paste the link below and download it's free.
http://support-th.canon-asia.com/contents/TH/EN/0100601701.html
This driver supports and it works
03-29-2017 03:27 PM
@Basty123 wrote:I just bought the CanoScanLide 120 and I have Windows 10. I have found the solution for Canon LiDE 120 error message: "Cannot communicate with scanner for these reasons:" Paste the link below and download it's free.
OS
- Windows 10
- Windows 10 (x64)
- Windows 8.1
- Windows 8.1 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
I made an account on here just to say that the above driver worked. I left the scanner plugged in. And just proceeded with the install. It over wrote the old driver and is working like a dream now. I'm using Windows 10 64 Bit
10-07-2017 05:51 AM
10-20-2017 03:09 AM
Hello,
I come from Vietnam. I have same issues with this scanner. This thread help me to save a lot of time. Thanks you for everybody and Canon please fire the person whom take our time !
I confirm this drive fixed the problem:
12-07-2017 08:27 AM
05-10-2018 09:46 AM
I have the same problem on upgrated computer with windows 10 Pro installed and additional front USB 3 ports.
I was using the front ports(USB 3) without success on higher resolutions(600).
Then I used the original mother board ones. And so far it was successful.
My quess is that the original motherboard ones have better USB 3 power supply management!
The scanner itself is powered from the USB. It has requirements for the 'USB' power capabilities i.e. it still have moving parts
(stepper motor).
Therefore when weak USB power powers the USB electronics then during the scanning process it causes the power drain and the weak power management of the USB board either causes insufficient power to the electronics or somehowe interfers the communications and causes the communication failure.
If you have these problems, try to you the USB power Boost ... ?
