04-25-2022 05:09 PM
Camera body is disgusting. These binoculars are not cheap and work well except for this problem which makes them unusable. This is a manufacturer's defect and in my opinion, Canon should compensate the customer.
11-26-2023 12:55 PM
My binoculars are old but have been stored indoors, heat and A/C. Deterioration is an act of life. Same with my fishing alarms. Clean it off, spend $$$ to have it recoated, live with it.
01-04-2024 07:34 AM
I've found another easy solution> UV light removes the stickyness. Put the binoculars under a UV lamp for 24 hours and the sides exposed directly to the light will be'dry' and not sticky,
04-24-2024 03:45 PM - edited 04-24-2024 03:45 PM
have had the 10x30is binocs for 15 or more years.. Canon will NOT make good on them.. the 'fee' you mentioned --what Canon wanted to charge me after sending them in-- was MORE than the binocs cost.. shame on Canon
05-01-2024 03:56 PM
Yep I learned the fee is over $200 so be prepared. If you had dropped them or had battery corrosion, or some other issue, I'd say it's worth it since a new pair is $500. According to the rep I spoke with, they pretty much refurbish to new condition by replacing a bunch of stuff. They don't just replace the exterior panels. I didn't get all the details but I was OK with refurbishing these to last another 20 years. I've had mine since 2004.
05-02-2024 11:25 AM
I spoke too soon.... I got a new quote saying "new prisms" and not much explanation. The original agreed price was refunded and a new quote was given for $330. Now we are getting close to buying a new pair. Canon certainly has some arrogance. I asked to send them back, sticky but working like they used to... I have doubts about getting them back in good shape and Canon in general.
05-02-2024 11:46 AM
Hi there!
The first estimate was based on an initial examination. The cost was based on a "Standard" repair. Once a technician evaluated your binoculars, it was determined additional time and parts were required, thereby making this a "Major Repair," so a re-estimate was generated.
Your estimate reflects the change:
05-02-2024 11:57 AM
I would understand if the binoculars weren't in your possession for the first and second quotes. I'm now really worried about what I get back. They don't 'need' new prisms or really anything other than a non-sticky exterior. They are great binoculars and were working when I shipped them. If the repair is the same cost as a new pair, why not just offer a credit towards a new pair? It was this thread and your comment that there was a 'fee' that made me think this might work out. Instead, it's a situation where for the cost of a new pair, you'll make your perfectly working binoculars non-sticky. And btw, how long will the rubber exterior last on the repair? 90 days, maybe a year? Then buy a new pair? Just trying to make sense of this situation while being quite frustrated.
08-01-2024 02:13 PM
So, my question is: Has this issue been addressed for NEW issues of this model? I am strongly interested in purchasing these, but would like to know if there were revisions that will prevent the stickiness from forming in the first place.
08-01-2024 04:08 PM
Yes, you're making the point I made pretty well here.. no explanation. The binoculars functioned perfectly, just had sticky panels. "prisms will need to be replaced" doesn't mean much to me. When they were returned to me, they worked fine. So not sure what the prism problem really was.
However, I was able to negotiate with Canon to get a replacement pair. It wasn't clear that's what they were doing and there were some emails and a few communication gaps. But in the end, I feel Canon did me right. The 'new' pair feels a little less 'solid' than the first pair but they work perfectly and aren't sticky. I still paid for the replacement, close to the original price quoted so I felt like it was a fair deal and I'm completely satisfied.
The trend here is there is a lack of transparency in communication. That seems to be a common theme with Canon. However, I like the products and the support works out in the end, so I'm pleased. This worked out a couple months ago... Just thought I'd reply here and finish this story.
09-24-2024 03:56 AM
I had Canon IS II 12 x 36. They were black and gummy. I took a clean rag and a bottle of rubbing alcohol. I put the rag around my finger, squirted on some alcohol and rubbed. When finger was black I did it again on a clean portion. After about 50 times of moving my finger over, taking about half an hour, I got non-sticky binocs that look like those above. I folded rag to get into small spots. Maybe a tooth pick or Q-tip would have helped. But it went fine.
