10-04-2014 01:01 AM
10-04-2014 10:24 AM
@GrumpyMonk wrote:
Thanks for the response, Bob! It's very true, I often suffer from sore neck syndrome with just the 70-300 that I've used until now. I have been thinking about a hip holster system. If I go with something like that, my concerns are whether the movement of walking around (maybe sometimes vigorously) with the camera hanging upside-down at my hip by its tripod mount mount would cause any damage or undue stress to the lens/camera mount. Do you have any experience with this type of configuration? Would it be better to attach the holster plate to the lens' tripod collar instead? Thanks!
I don't have any such experience. but one reason I've never tried the Black Rapid system is because of reluctance to have a heavy camera dangling from the tripod mount. (There have even been cases where the BR attachment point gave way, but I'm pretty sure BR has fixed that.) In the absence of a purpose-designed solution, your idea of attaching the lens to the holster mount may be a good one. My 70-200 certainly seems to be a lot heavier than any of the camera bodies I've used it on. And the tripod collar would be closer to the center of gravity of the camera/lens system than the camera's tripod mount would.
10-04-2014 09:21 AM
It will be harmful to the mount that connects your head to your shoulders. I'm a strong believer in using a neck strap; but if I were going to be doing a lot of walking with a 70-200, I'd either leave it in my pack until I needed it or try to rig some sort of holster arrangement to keep the camera from being jostled around and keep the weight off my neck. Otherwise, I'd expect to be mighty sore at the end of the day.
10-04-2014 09:37 AM
10-04-2014 10:24 AM
10-04-2014 01:57 PM - edited 10-04-2014 01:58 PM
10-05-2014 05:05 PM
10-18-2014 11:54 PM
