11-17-2020 11:28 AM
I will like to know if anyone have the full version of Big Sur OS and EOS Webcam Utility full version working together. If theres any bug or trouble using both together. Thank you
11-23-2020 05:11 AM - edited 11-23-2020 05:12 AM
Yes, I got it up & running on my MacBook Pro 13" 2017 with Big Sur. Just make sure, that the EOS Utility doesn't run at the same time.
04-09-2021 05:24 PM
04-09-2021 06:21 PM
Which mode do you have to set on the dial to make it work best? I only tested it with the settings menu of teams and in mode A on the dial, and it did not focus automatically. I did not make a call yet because i want to be sure ahead that it works well.
08-31-2021 05:38 AM - edited 08-31-2021 05:39 AM
For me is the same, I have a Canon EOS R and an M50., running BIG SUR on my mac mini M1, plugged in with a high-quality USB to USB-C cable.
I downloaded the Web utility for Catalina, because apparently in the BigSur list does not exist yet (see attachment)
Opening Zoom (opening zoom updated) and I cannot f***ing select any EOS web utility from any of Zoom, or Meet or Hangout or whatever.
Web-Utility is recognized ONLY from OBS for live streaming.
ANY SUGGESTION? I am freaking out sincerely.
Is there a particular setting I have to do on the camera? or I have to follow some particular steps?
I am FRUSTRATED!
08-31-2021 03:58 PM
Hi. I don't know if this will help. I had the same problem with EOS Webcam Utility. I have Big Sur installed on my new Mac Book Pro. My camera is EOS 90D and I use HDMI. And Zoom would find EOS Webcam, but the screen was black. I bought Cam Link 4K from Elgato and installed the driver for Elgato Thunderbolt. The Cam Link works and I can now see the videorecording from my camera.
09-05-2021 08:08 PM - edited 09-05-2021 08:09 PM
Hi all.
According to some people, eos webcam utility is not working in apps that are optimized for M1 chip... so, it will not work in Meet and Zoom. However, there is a quick solution. Download OBS and install eos webcam utility, then in OBS use the option "start virtual camera" and that's it. You should be able to see OBS virtual camera in any app that uses a web cam.
Hope it helps.
My gear:
Canon T6
MBA M1
usb cable
TKDY Power supply for dslr
Cheers!
A
