EOS Webcam Utility + Apple Silicon / M1 Mac
optimal_flynn
EOS Webcam Utility doesn't work with apps like Google Chrome with M1 Macs, but it should be able to easily with some help from Canon.
I recently switched to an M1 powered Macbook Pro from an Intel one and noticed that after installing the utility, it didn't show up as an available camera. Doing some internet searching including on this forum I found the following advice:
1. Use OBS Studio as a virtual camera.
2. Use the x86 version of Google Chrome in Rosetta
Neither of these are a great option though as running OBS is purely band-aid and the x86 version of Chrome in Rosetta has a massive performance hit for me on my machine.
So I decided to do some debugging as to why it wasn't working. (Why does it work in OBS and perhaps some other places but not in Chrome) and it's actually really simple:
Error loading /Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility: dlopen(/Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility, 0x0106): tried: '/Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility' (mach-o file, but is an incompatible architecture (have (x86_64), need (arm64e)))
Chrome (and probably other apps) bail out when they try and grab the device because EWCService / the CoreMediaIO DAL plugin is compiled for x86 instead of ARM.
I don't have access to the source code (the community would help with these issues if you open-sourced it Canon btw 😉) which limits my ability to go further, but my strong theory is without much work if the existing EOS Webcam Utility for Mac was just compiled / available for ARM then it'd work with a bunch more apps. It could be as simple as changing the build target.
Is there a place we can write up tickets for the EOS Webcam Utility team?
21 REPLIES 21
I couldn't get that working with FaceTime.   Other apps, yes.  Not FaceTime.
Cascable Pro Webcam works for me, but not OBS.
