EOS Webcam Utility + Apple Silicon / M1 Mac
optimal_flynn
EOS Webcam Utility doesn't work with apps like Google Chrome with M1 Macs, but it should be able to easily with some help from Canon.
I recently switched to an M1 powered Macbook Pro from an Intel one and noticed that after installing the utility, it didn't show up as an available camera. Doing some internet searching including on this forum I found the following advice:
1. Use OBS Studio as a virtual camera.
2. Use the x86 version of Google Chrome in Rosetta
Neither of these are a great option though as running OBS is purely band-aid and the x86 version of Chrome in Rosetta has a massive performance hit for me on my machine.
So I decided to do some debugging as to why it wasn't working. (Why does it work in OBS and perhaps some other places but not in Chrome) and it's actually really simple:
Error loading /Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility: dlopen(/Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility, 0x0106): tried: '/Library/CoreMediaIO/Plug-Ins/DAL/EOSWebcamUtility.plugin/Contents/MacOS/EOSWebcamUtility' (mach-o file, but is an incompatible architecture (have (x86_64), need (arm64e)))
Chrome (and probably other apps) bail out when they try and grab the device because EWCService / the CoreMediaIO DAL plugin is compiled for x86 instead of ARM.
I don't have access to the source code (the community would help with these issues if you open-sourced it Canon btw 😉) which limits my ability to go further, but my strong theory is without much work if the existing EOS Webcam Utility for Mac was just compiled / available for ARM then it'd work with a bunch more apps. It could be as simple as changing the build target.
Is there a place we can write up tickets for the EOS Webcam Utility team?
21 REPLIES 21
wanqiang79
One "workaround" is to download and install the free streaming software OBS.  It recognizes EOS Webcam Utility camera (you may need to shutdown EOS Utility 3 first), and with OBS's virtual camera started, it presents an OBS Virtual Camera video source to other apps.  This seems to work on my M1 Silicon Chip MacBook Pro running macOS Monterey.
This worked for me / is the right answer. Just pay attention to top comment on the youtube video. You have to download the OBS version for Intel not M1. EOS Webcam Utility (intel) + OSB (intel) led to success on M1 Max for me. Hope this helps other folks. "Accepted Answer" that this will not work is contrary to my experience.
I'm not sure why this is marked as a solved when no solution has been provided yet for this issue. Please unresolve it until the issue is actually addressed.
I've seen this solution offered but it isn't working for me.
EOS webcam utility was released in Asia for Mac silicon. https://asia.canon/en/support/0200629304. I downloaded this update for my M1 Max and now EOS integration works fine. Nevermind the won't-solve post.
siocone
I use an Apple M1 and I have a 5D Mark IV
in OBS, the webcam function works (although only after a few tries) in teams, the cam is displayed and also worked. no connection can be established in zoom and not easily in discort either... new software with better stability would be really super helpful, possibly also for facetime and other tools with better functions (e.g.) aperture rules
Wow, great, "Asian" webcam utility works perfectly fine on my M1 Mac Mini so far!
Jan6D
The latest "EOS Webcam Utility Pro Windows / Mac v2.0" seems to work on my M1 Mac Mini and Ventura (13.0.1) (unfortunately only in Rosetta, no Apple Silicon version there yet)
https://www.usa.canon.com/cameras/eos-webcam-utility
This is not a fix. I still have to use a third party streaming app to connect camera operating programs like Zoom to the Asian EOS, I can’t open the Asian EOS as a stand-alone software, and my M50 freezes after a few seconds regardless of which programs I use.
that's another notch in the let your software engineers know M1 mac's need the integration. sooooo many people are switching to Silicon Macs.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
