10-25-2022 07:31 AM - last edited on 10-28-2022 09:58 AM by Danny
I have just bought a new Canon 250D and intend to use it as a webcam. When using the Canon Webcam software, I am experiencing a delay, which is semi-noticeable with speech but very much so with a clear action such as clapping of hands.
I have updated the camera firmware, tried a myriad of different USB cables and different programs (Zoom OBS, etc). I have also tried using the HMDI out, via a number of capture cards via USB 3 but the same delay appears. I tried changing the resolution of the camera but all five options produce the same result.
I'm at the point I will have to return the camera if I can't work out what I need to do to get it right.
Is there anything you can suggest I try?
Thanks!
Sam
10-25-2022 10:03 AM
Hello. Please see the FAQs listed HERE.
10-25-2022 04:08 PM
Hi Stephen. Thanks for the reply. Yes, I did read that (and all the other help things I could) but it doesn't address the delay. Did I miss something?
10-25-2022 12:37 PM
Your streaming software should have a place to adjust the synchronization of the audio and video. OBS has this feature.
10-25-2022 04:10 PM
Hi 5DIV. Thank you for your suggestion. I can't see how to do that in Zoom.
My other issue is that that isn't actually fixing the issue, just delaying the audio. I was hoping how to find out how to fix the video delay to make it a full live feed
10-25-2022 04:38 PM
I could be wrong, but I don't think that the delay is a Canon camera problem. If you search online, you will find many hits concerning the delay with Zoom. There may be a solution in a Google search.
