04-11-2015 08:03 PM
I just purchased a Canon T4i. I am looking to purchase a GPS of it. What are the Pros & Cons to it?
04-14-2015 12:22 PM - edited 04-14-2015 12:29 PM
I use the GPS-E2 with my 5D III. It mounts up in the hot-shoe (where you'd normally connect an external flash).
You can control how often it does a location fix (the more often you have it get your position, the more battery it goes through. I set mine to 30 second intervals because I'm walking on-foot so it's not like my position changes very much in 30 seconds. The battery lasts a LONG time at 30 second intervals. It does run on a single AA size battery. I carry a spare, but I never seem to need it.
The device also has an electronic compasss and can record the direction your camera was facing at the time you took the shot.
Lastly, it can also do "logging" so you can optionally have it store the "bread-crumbs" of your path throughout the day. You can export these as ".KMZ" files (compatible with things like Google Earth). I only use the tagging... I never use the logging feature.
One last little thing (kind of important)... the GP-E2 includes a cable that can be used to attach the device to a camera like a 7D becaue the 7D isn't able to communicate to the device through the hot-shoe (the other supported cameras can and do communicate through the hot-shoe) -- so that cable is normally not needed unless you'd rather wear the GP-E2 somewhere on your body to keep your hot-shoe free for other devices. HOWEVER... you'll notice the end of the cable that plugs into the side of the GP-E2 seems to be a proprietary plug -- not a USB standard shape. This drove me (and several other people) nuts trying to figure out how to connect the GP-E2 to the computer to unload the logs (if you choose to use logging). It turns out... that the USB plug on the side of the GP-E2 is a dual-purpose plug. It fits the special cable that was included with the GPS but it ALSO fits a a USB type "mini-B" plug. That means the SAME cable that Canon included so you can connect your T4i to the computer to unload images... can also be used to connect the GP-E2 to the computer. That little fact was not obvious (nor could I find anything in the documentation to make that clear.)
04-12-2015 10:02 AM
There are no Pros & Cons to the generic term GPS any more than asking "I want to buy a lens. What are the pros & cons."
Are you looking to buy the Canon GPS-E2 or a separate data logger? Then you can get useful answers.
04-14-2015 08:04 PM
Not a very "user freindly" reply John!
But, thank you for replying.
cpc1
04-14-2015 08:15 PM
04-14-2015 09:04 PM
John,
Thank you for the reply.
My goal is to record the location of future photos that I may take for documenting and to be able to return to that location at a later date if so desired.
Is a GPS unit what I should consider or should I consider the option that you mentioned, a stand alone data logger a better option? Since I don't know the difference, can you share the Pros and Cons to them both?
I am very comfortable with a computer. I consider myself an Intermediate user. I would say, $100.00 would be a starting budget point.
Any insight and advise you can give will be welcomed.
Chris
04-14-2015 09:17 PM
04-14-2015 07:55 PM
