12-16-2012 08:06 AM
Hello,
I just bought canon 650D and i have problem with connecting it to PC through usb cable. It can't find automaticly Canon 650D (t4i) driver, can anyone help?! 🙂
01-09-2013
06:59 PM
09:35 AM
Stephen
Hi Andy,
At this point, I recommend that you contact us at this link if you're in the US, or http://www.canon.com/support/ in other countries, where we'll be better able to assist you in resolving this connectivity issue.
12-16-2012 11:23 AM
Did you install the software that came with the camera? If so did you get any error messages?
12-19-2012 09:20 AM
Yes, i installed all that software which was in that CD, and no didn't had any error message 😕
12-20-2012 11:00 AM - edited 12-20-2012 11:01 AM
4 questions.
1 - What Operating System are you using?
2 - What functionality do you expect to accomplish with your PC (just download pictures or tethered shooting)?
3 - What version of EOS Utility are you running?
4 - The CD usually has older versions of all the software. Havw you updated them all by going to the Canon website and downloading the latest versions?
12-21-2012 09:23 AM
12-21-2012 11:43 AM
There have been problems with 64bit windows - possibly not supported by the Canon software your running.
In cases I'm familiar with, users have to launch a Virtual session of Windows XP to get tethering to work.
Possible the Canon people (or other users running 64-bit windows) here may be able to provide more guidance.
12-24-2012 09:04 AM
EmiilsLV,
What devices are connected to your computer other than the camera, keyboard and mouse?
12-24-2012 09:18 AM
Printer ( old hp 1200 ), headphones and that's all.
12-25-2012 06:30 PM
If you can try changing the settings for the connection to Print/PPTP as opposed to PC Connection and see if that works
12-30-2012 11:46 AM
EmiilsLV,
Try disconnecting the printer, then restarting your computer and see if you are still unable to connect to your camera with EOS Utility.
