04-09-2022 04:35 PM
Is anyone having trouble installing the firmware update for the rf 100-500 lens on a Mac? I get the .afu file from the dmg but the .afu won't install on the card. Thanks for any help.
Mike W
04-09-2022 09:56 PM
Glad it worked out. Can you please mark as resolved!
04-09-2022 08:15 PM
Hi Mike:
Sorry to learn you are having issues.
What precisely do you mean when you say "install on the card"?
04-09-2022 08:24 PM
Sorry about the wording. I downloaded the dmg to a mac from the Canon website. I extracted the eosr5152.fir and put it on the desktop and then tried to install on a sandisk pro sdxc card. The card is in a Lexar card reader. When I drag the .fir file to the card directory, the file will not load. Frustrating, but I appreciate your response.
Mike W.
04-09-2022 08:31 PM
to clarify further, I'm having this problem with the r5 152 update and the update for the 100-500mm rf lens.
04-09-2022 08:34 PM
Likely a silly question, but is it possible the write-protect slot on the SD card is set to protect?
04-09-2022 08:44 PM
The reader won't accept the card if the tab is in the locked position, so that isn't it. However I get a brand new error message when I connect the card to the Mac via the reader.
macOS can’t repair the disk “EOS_DIGITAL”.
You can still open or copy files on the disk, but you can’t save changes to files on the disk. Back up the disk and reformat it as soon as you can.
So it seems this is the problem. I have other cards and will try one tonight. Thank you again for taking the time to look at this.
Mike W.
04-09-2022 09:00 PM
Definitely, the card sounds suspect and trying another card is the next logical step. Hope it helps - let us know if it does.
04-09-2022 09:54 PM
The problem was the card, which is/was my most recent purchase. I can still record raw files to it and examine them in Bridge but I think it's time to discard. Thank you.
Mike W
04-09-2022 09:56 PM
