EOS DSLR & Mirrorless Cameras
7D "Busy" Problem
I have a 7D (first gen).  it works fine except when I have my 70-200 Canon f/4L on ith with both a Canon 500D close-up filter AND a circular polarizer.  With that combination, it will hang-up and register as "busy."  The only way is to take out the b...
caquino by Apprentice
  • 11661 Views
  • 6 replies
LCD Screen (EOS Rebel T5)
I have the T5 that I got just a week ago and the LCD screen just started having issues. I provided pictures for a refrence.  The screen still is functional, but the pixels act up from screen to screen. What is causing this problem?
Resolved! Dual Pixel CMOS AF
I just bought the 70d and it is amazing. The auto-focus for video is stunning. I wonder if there are any other canon cameras that use the same focusing system as the 70d (Dual Pixel CMOS AF).
gafool by Contributor
  • 3710 Views
lines on pictures
Why do I have horizontal lines and purple haze on my pictures and vertical lines on my video on my Rebel T3? Sometimes I get clear pictures, but mostly not.  I have read on the web that there may be an image sensor problem. Any ideas? The camera is 2...
matlet by Apprentice
  • 7797 Views
  • 2 replies
REBEL T3 TO BE TRASHED
Bought a REBEL T3 last August 2014. On a few occasions the power needed to be turned on and off to get the camera on. Tonight it is now giving me ERROR 30. Found another forum with suggestions to clear problem but none have worked. This is apparently...
Flash
can my rebel t5/1200d work with a Yongnuo Professional Flash Speedlight Flashlight Yongnuo YN 560 III and what can i use for audio cause my rebel t5?1200d cant use an external mic ,what can use for better audio quality.
Ojani by Apprentice
  • 4433 Views
  • 3 replies
Canon Rebel T3i deleting pictures?
I have a canon eos rebel t3i and I was using it to take pictures at prom. I took a lot of pictures and when I went back to view the half of them deleted and a few others said "cannot view image". I dont know whats going on because I did not delete an...
Extremely glitchy video on EOS Rebel T3I
https://youtu.be/ZwgKsjhtfOA I've had this problem for around a year now, but never actually made an effort to fix it because I never used the video function. Now, it's really bugging me as I have an Activities Week vlog that I need to make for a vid...
Marcus by Apprentice
  • 3164 Views
Resolved! Canon 5D Mark III. Images disappear
Canon 5D Mark III. Images show on camera screen but CF card shows to be empty when connected to computer. Used two different CF cards, same result. Tried Sandisk Rescue program but no current images were found. Image counter goes down with or without...
7D MK2 Video Drop 3 Frames
My 7D MK2 drop frames in video mode on 50 FPS FullHD when i'm using camera i P mode. 3 frames, audio is OK. It's on different light conditions and on different movment of camera (steady or quick paning). Problem Solved: The issue is in moment when ca...
Sabin by Apprentice
  • 2893 Views
  • 0 replies
