EOS DSLR & Mirrorless Cameras
5d mk III RAW issue
 Hey, i'm experiencing issues with the RAW files. I think there might be a sensor problem because i tested the original file on another computer and it's the same. Attached here, u have the same raw file exported in Digital camera Proffesional and Li...
LCD Display Problem
All of the sudden my Mark2 has black / prurpolish horizontal line at the top. it is only in display, when you trasfer the pic of computer,there are no lines.  Please helpIt looks like this
YKNA by Apprentice
  • 5391 Views
  • 7 replies
Resolved! EOS 700d menu
Hi,I recently bought EOS 700d camera. When I go to the menu I see fewer options (7 in all) for example I see only 1 camera option where as the manual shows 3. Also I don't have 'flash control' setting in my camera which in manual is shown as last opt...
S700d by Apprentice
  • 6383 Views
  • 2 replies
7D Mark II LCD not working.
Brand new out of the box LCD not activating via the menu, info, 'Q', nor live view. Camera operates otherwise fine. Takes photos and I hear the mirror flip up for live view recording. In General, however, I cannot get the LCD to display anything at a...
Attaching lens shuts 7D down
Aloha! I have a Canon 7D. It won't turn on with a lens attached. The body alone turns on fine, but when attaching the lens, it shuts down. It isn't the lens because I tested it on a 5D with no problem. Ideas? I cleaned the contacts with alcohol, but ...
GBHajim by Contributor
  • 6431 Views
  • 10 replies
Resolved! new SL1, Q Set button always defaults
SL1 body. When pressing the Q Set button it always defaults to Image Quality and does not allow me to manually change to other settings using the arrows. I know I can use the touchscreen to do so but I've been a Rebel T1i user for many years obviousl...
daverave by Apprentice
  • 4009 Views
EOS utility
Old laptop died so I just bought a new one w/ W10.  Where can I find the software download for EOS utility so I can get back to getting my photos on the computer? On the Canon website, I only found an update, not the actual software.  Tx
