EOS DSLR & Mirrorless Cameras
Macro photo exposure 700D
When taking a photo of an insect on a plant I wish to set aperture at around f18 and shutter speed at around 1/250 to freeze subject movement. This means setting to manual where I would then want to set to auto ISO, but auto ISO is greyed out in manu...
mike21 by Enthusiast
  • 6923 Views
  • 12 replies
Can’t connect to smartphone
I purchased a t6i for Xmas but I’m having trouble connecting to my iPhone 6 Plus with the Canon Connect app. I’ve completed the set up, enable, etc. with a password from encryption code. It worked the first time after I typed in the 8 digit number. H...
70D - Losing left audio channel
This is something I have never noticed as I don't record audio to the camera directly most of the time, and when I do, I typically send mono to it (which hides the issue I am about to point out). However, this month we lost quite a bit of video causi...
jh20001 by Apprentice
  • 3032 Views
  • 0 replies
Resolved! upgrade to 5d mk iii
A bit late in the day to ask advice after the fact I know, but I have recently upgraded from a 7D mki to a 5D mkiii (the MKiv being a bit pricey!!) Was this a good idea? I should say that I shoot mainly land/cityscapes and occaisional portrait and ve...
Knysa by Apprentice
  • 6454 Views
  • 9 replies
T5 video questions
Hello,I have recently been messing around with my T5, trying to shoot in video mode and what not. I guess the video is all right, but yesterday I was filming at a park by a river and it was so bright that the picture was almost washed out.I have been...
Joak by Contributor
  • 9843 Views
  • 5 replies
EOS-M5 & L Series lenses, plus more.....
Hello from the UKI’ve been a lifelong user of Canon cameras. From the original 35mm EOS cameras and all the way through the transition to digital. It would take an age to list what I have owned and used over 30 odd years. So I will refrain from doing...
TheRogue by Enthusiast
  • 26500 Views
  • 70 replies
Rebel t6 and hotspot
I am using the camera connect on my t6 and it works fine on regular wifi. If I move outdoors I would like to use the phone hot spot.I can see the connection in my camera and put in the password but it won't connect. I notice that the ssid in the app ...
rparson by Apprentice
  • 4135 Views
Import 1D X files to iPad
Trying to import files from my Canon 1D X to my iPad using the USB3 Camera Connector. Works fine with my Canon T5i and a T6s. All I get when I connect my 1D X is grey squares; no images. Camera disk light flashes and if I select Delete Photos the fil...
T7i Focusing Issues?
So... I've shot a few images with a T5i, and then with the T7i (both in manual, same settings, and using a 24-105 Canon lens), and I consistently find that the images shot with the T7i are always out of focus. The camera will tell me, when reviewing ...
rgfoto by Contributor
  • 18935 Views
  • 28 replies
Canon SL1 Camera
He there.  I am new to this forum as of January 22 2018.  Does anyone know if a Canon 420 EZ Speedlight flash will fit my Canon SL 1?  Thank you in advance.  I have a chance to buy a used one for $40.00. Is this a good deal?
veejay by Contributor
  • 3758 Views
  • 3 replies
