hello
ramikchaich
I have enabled live view by pressing the Start/Stop button, and the picture shows on the LCD monitor.  I then take a shot.  But nothing is recorded on the card, and the picture dos not show on the LCD monitor (instead it just keeps showing the live view).  There must be a simple explanation and solution?... i tried to reset all options and i have the same probleme .and its new d5 mark3 i used this camera for 2 month only
3 REPLIES 3
TCampbell
Does the camera believe it has been able to lock focus on a subject?  In "One Shot" mode it wont take a photo until it believes it has achieved focus.
As a test, try switching the auto-focus switch on the lens over to manual (set AF/MF to MF) and see if it actually takes and records the shot when you press the shutter button.  If so, it likely points to a focus issue.
Tim Campbell
5D III, 5D IV, 60Da
That sounds like it's in Video mode.
It does, but it would still capture a photo, though.  I've had that switch accidentally changed position on me, and the camera winds up taking 1040P snapshots.
