02-14-2016 10:31 AM
When transferring photos to my iPhone, I select a video to transfer but it says that it cannot transfer that file type. Is there a way to transfer videos to your smart phone or not?
05-01-2017 08:34 PM
05-02-2017 06:39 AM
I think that ipads & iphone prefer videos in .mp4 format, check in your 70D manual to see if you have the option to record in .mp4 otherwise you will need a seperate video file converter to reformat the files to the correct type.
05-05-2017 05:59 PM
Hello ManleyRunner,
The Camera Connect app is able to handle video transfer from compatible EOS DSLR cameras provided the movie was recorded in the MP4 recording format. If the movie is in the MOV recording format the application is unable to transfer it.
The EOS 70D records in the MOV recording format, which is the reason that message appears which says it can't transfer that file type. As another member of the forum has suggested, you may need a third party video converter to try and convert the file to the correct format.
05-05-2017 06:02 PM
Hello Tico,
As I was explaining for another post, the Camera Connect app is able to handle video transfer from compatible EOS DSLR cameras provided the movie was recorded in the MP4 recording format. As the EOS 70D records in the MOV recording format, that message appears which says it can't transfer that file type and will not work.
Another member of the forum suggested that you may have success in converting the file, via a third party video converter, to the MP4 format.
07-20-2018 03:16 AM
How would I change the movie encoding within my camera ? It records in whatever format it does and I don't have a setting option to change it. I am using latest firmware, EOS remote and android v7.
10-30-2018 04:50 AM
| I use Avdshare Video Converter to Convert any Canon camera or camcorder recorded video format which is unsupported by iPad or iPhone to iPad or iPhone supported one. |
10-30-2018 04:52 AM
Well, most of Canon EOS DSLR Cameras record video in MOV H.264 and it is a supported video format by iPad or iPhone.
Of course, there are other Canon series, like EOS M Series Digital Cameras, PowerShot Digital Cameras, Cinema EOS Cameras, High Definition PTZ Cameras, etc which may record videos in iPad or iPhone supported video formats or may not. So if your Canon camera recorded video format in AVCHD or in some other video formats other than iPad or iPhone supported H.264 or MPEG-4 in M4V, MP4 or MOV format or Motion JPEG in AVI format you will fail in transferring the Canon video to iPad or iPhone for playback.
10-30-2018 04:53 AM
Some Canon camcorders record video in AVCHD or MP4 H.264, such as XA15 model and some other Canon camcorders record video only in MP4 H.264, such as XF405 and XF400. And among the Canon recorded video formats, only MP4 H.264 is supported by iPad or iPhone.
10-30-2018 04:54 AM
