10-10-2014 09:32 PM
Mark 111 changes white balance for no reason at all, on the same pic
10-11-2014 01:50 AM
There is nothing strange to it. Different part of the photo can have different color temperature. Thus, the white balance is different for each of those part. This happen a lot if you shoot indoor with mix outdoor light.
10-11-2014 08:07 AM
Easily correctable in post. ![]()
10-11-2014 10:10 AM
10-11-2014 10:41 AM
@larryj wrote:Mark 111 changes white balance for no reason at all, on the same pic
Balancing off the color temperatures of competing light sources is difficult for any camera. But my impression is that my Mark III does at least as good a job of it as any other camera I've owned. If you shoot RAW, you can always overrule the camera with a photo editor.
10-13-2014 11:24 AM
Larry, you don't mention your shooting conditions, or whether or not you use auto WB. Auto WB will change constantly, every time the camera meters a shot, and can change dramatically if you're in mixed lighting, or there are color casts or whatnot. Also, flourescent lights actually change colors themselves. So you could shoot the same composition in a quick burst and have significantly different WB and even exposure.
10-14-2014 08:42 PM
thank you
10-14-2014 08:49 PM
I have tryed to use the different setting but still does not act like my 50d using same lens. this camera is a 5d mark111 . THANkS I will try more RAW
