While taking pictures of a full moon I am ending up with a ghost image.
hlk2nmj
Is this because of the filters being in place? Input please. Canon T5i with EF5 zoom 18-135mm. I was using auto function without flash.
TCampbell
Bright objects, and especially bright objects on mostly dark backgronds, can create "ghosting" when you have flat filters attached to the lens.  The flat surface makes a perfect "mirror" and some light reflects off the front of the lens, hits the filter, and reflects back into the lens creating the "ghosted" copy.
Higher quality filters usually have a good anti-reflective coating to reduce the effect, but I find it's better to just remove the filter completely and only use them when they are needed or helpful.
Tim Campbell
5D III, 5D IV, 60Da
8 REPLIES 8
jrhoffman75
If by "ghost image" you mean that you see a faint second moon then maybe it is reflection from filters. You can easily and quickly test that by removing filter and repeating the shoot.
Thanks, John. I should have tried that instead of posting the question but it doesn't hurt to ask, right?
jrhoffman75
Never hurts to ask. If you can post the image it would help diagnosis.
Deleted bad images. Should have a good moon tonight and will try without filters. I'll let you know how that goes.
Henry
You probably know this, but the full moon is in full sunlight, so you want to spot meter on the moon or try a "Sunny 11" exposure for a start. f/11 to a shutter speed close to 1/ISO.
The Looney 11 rule is a method of estimating correct exposures without a light meter. For daylight photography, there is a similar rule called the Sunny16 rule.
Using a ISO 100 setting,you will set the aperture to f/11 and the shutter speed to 1/125 second.  Or, you can use any combination of these exposure but must maintain the same EV.  I.E., ISO 200, 1/200, f11 --- ISO 400, 1/500,  f11, etc.
Noted, a135mm lens may not be a long enough focal length.  Depending on your desired out come.  Use manual mode for the settings. Shoot RAW, otherwise set the jpg to daylight.  Use a tripod.  And lastly bracket your exposure, a stop more and a stop less.
EOS 1DX and many lenses.
TCampbell
Tim Campbell
5D III, 5D IV, 60Da
hlk2nmj
I appreciate all the input on this subject. Simple fix was just removing the filters. Thanks to all the contributors!
