03-31-2014 09:52 PM
I was "T.H.I.S." close to buying the 70D. I have read WAYYY too many posts about issues with the focusing on the 70D. How is Canon handling the issue? I would love to buy this camera, but not willing to gamble with that much money.
01-25-2015 05:50 PM
So I sent my camera back and Canon claims there is no problem. So apparently I somehow unlearned how to point the camera at a target, achieve focus lock confirmed by the beep and AF point flash, and get completely out-of-focus shots.
I'm struggling to contain my frustration as I await the return of my 70D body in order to do more testing to relearn how to use single-point AF (something I've been fine with for 15 years prior to the 70D).
smh
01-27-2015 03:44 PM
<sigh>
Canon said nothing was wrong and did not do anything to repair/calibrate the focus. I conducted a fixed test and pasted the 100% crop of the results here: www.flickr.com/photos/darkeyedredhead/16197146217/sizes/o/
All were single-point focused, f/5.6 400 ISO 1/80 on a tripod. It is undeniable that every other point (even when above and below the target line on the 45-degree slanted chart) were better focused. And the focus points immediately to the left and the right are tack sharp crystal clear perfect.
No problem with the center point focus? Bull.....
Since Canon won't help, I sent mine back to the retailer for an exchange of defective product. I am sincerely hoping my $2,500 total cost of changing to the Canon ecosystem (lenses, accessories, etc.) was not a mistake. I am now wondering if the Nikon D7100 would have been the better choice after all. I'm crossing my fingers the next unit will perform properly so I can stick with the 70D. I love everything about it...except for the major focus flaw built into it.
02-18-2015 12:53 PM
@Photogirl55 wrote:I was "T.H.I.S." close to buying the 70D. I have read WAYYY too many posts about issues with the focusing on the 70D. How is Canon handling the issue? I would love to buy this camera, but not willing to gamble with that much money.
I am in the exact same boat as you. I was about to pull the trigger and then happened to come across all of these reviews and then forums and then videos about this issue. There are WAY too many to think this was an isolated issue with only a few models. I see it is almost a year since your post and I still cannot seem to find any additional information. What's most scary to me is that Canon does not seem to admit there is an issue and readily come up with a fix. Did you ever end up buying the camera? Is there an update to this problem as far as you know?
02-18-2015 02:18 PM
Once again I wanted to chim in on this issue. I am a 70d owner with the same issues, and some other annoying issues with some simple stuff that canon left out, like a frame counter. But I will focus on the issue at hand. Yes, there are issues with this system dispite what canon and some owners may say but since we are stuck with them we can make the best of it.
I know that multiple focal points are one of canons selling features but I have found that they only serve to confuse the system. Use one focal point. You can move it anywhere in the frame you want but only use one. Second, it is not a full frame camera so we will naturally loose a stop (about, as a guess). In addition the focus is not as precise as we are led to believe. So my solution is to forget about any apeture larger than f8. F8 seems to give me the same depth as about f5-ish. I get about the right depth for a good portrait but still get a sharp subject. My science my be a little suspect but trail and error results seem to work well.
The 70d is not as versital as I really need and I still use my 5d Mk1 for almost everything, but it can be used. Trying to snap the white board for a custom white balance never works, and it has a few other annoying issues but at least I can work with that one.
02-23-2015 07:02 AM
Hi plz help
I am also facing a same problem , what should i do ? can i sent it back for service ? i took loan from bank and purchased it , i dont have money to purchase some other camera, plz help i am confused . i bought it nearly 8 months back.
02-23-2015 09:43 AM
definitely send it back. Go online to the cannon service and repairs and fill out a repair ticket.
I sent mine in and got it back - they are very vague about what they do to it, and i have had it back for a week+ and haven't had a chance to recheck it, but i will redo the test this week and see if it is still doing the same thing. I know how yo ufeel - these cameras are not cheap! I am new to photography as a "hobby" and have have invested about 7500 into building a canon kit from scratch, otherwise I would be changing to a different system. I plan to keep sending it back until it works 100% or until they replace it. (it may be working now, havent had a chance to reproduce the tests).
02-23-2015 09:48 AM
02-26-2015 11:06 AM
Unfortunately people reporting the 70D 'focus issue' went from a few cameras with a real issue, to ones that are perfectly normal.
The real issue was that in very few cameras when using a lens faster than f/2.8 it would focus differently when using the center f/2.8 PDAF point, and the other 18 f/5.6 PDAF points. This is not normal.
What is normal is for the PDAF system to need micro focus adjustment to match the Dual Pixel AF system. Unfortunately, a popular US photo blogger didn't understand the real issue and perpetuated the myth that having to MFA the PDAF system to match the DPAF system isn't normal.
02-26-2015 11:36 AM
02-26-2015 12:40 PM
@adrock318 wrote:
I just picked up the camera with an 18-135, a 55-250 and the 50mm 1.8. I'm not sure what you mean by PDAF, ...
Phase Detection Auto-Focus
