06-13-2021 11:39 AM
My custom shooting mode C1 setting is using a custom white balance for a studio lighting. Just wonder if I set a new custom white balance, would the new white balance setting replace my C1 custom white balance setting (disable auto update)?
My camera is 5DSR.
06-14-2021 10:09 PM
It seems the question is unclear.
Finally I got an answer from B&H. The answer is No, the new white balance setting won't change the custom shooting mode (C1, C2, C3).
06-14-2021 10:09 PM
06-15-2021 11:38 AM
@AnTroy wrote:It seems the question is unclear.
Correct. Page 144 of the manual.
If upadte is set to Disable the C1 etc won't be updated permanently, but any change you make will remain in place until the camera is powered off, manually or automatically via time out.
06-15-2021 12:31 PM
Usualy the changes reset just as soon as the metering timer expires.
