10-14-2022
12:04 PM
12:20 PM
Arthur
Hi! I'm having an issue where images are skewing to the right or left. Shooting with brand new Canon R6- mostly the RF 24-70 lens, but it also happened with my EF 85 while using the converter as well. Doesn't seem to happen every time, but enough that it's a problem!
I can't seem to recreate the problem at home. Any ideas on what I should do/check? I have googled, but haven't found anything helpful yet. Thank you!
including a more extreme example below:
10-14-2022 02:13 PM
What shooting mode are you using? Did this issue always exist with the camera?
I recommend setting the top dial to P shooting mode, and going into the menu system and reset the camera back to factory defaults. Next, switch the top dial to Green [A+] shooting mode. Take a few shots outdoors on a sunny day and see if the problem still persists.
10-14-2022 02:19 PM
Could it be a sensor shift problem?
10-14-2022 02:20 PM
Thanks! I'm shooting in manual. I just got the camera, so yes, it has happened on all sessions since then. I just can't seem to recreate it at home or figure out any rhyme or reason as to when it does it and when it doesn't! Thank you for taking the time to reply. I appreciate it!
10-14-2022 07:39 PM
Hello TWestgate. You mentioned it happening with the viewfinder. Does it do that when shooting with the LCD screen instead? Are you shooting RAW or JPEG? Is the camera rotated vertically in these photos? I would suggest putting the camera in A+ (Auto) mode and shooting some test shots there. If it seems to shoot fine there, then I would reset the camera as Waddizzle mentioned. With so many variables to touch on, you may want to contact our Technical Support Team at 1-800-652-2666, Monday through Friday between 9:00 am to 9:00 pm ET and Saturday between 9:00 am to 7:00 pm ET to further troubleshoot if this issue persists.
10-15-2022 10:25 PM
just a guess but could you be hitting the magnify button and zooming into the image and composing based off the zoomed image? for example with the photo you posted, if you zoomed into the couple to check focus and immediately took a picture, you might have thought that you were cropped into the couple but actually composed differently. to check for this, you can go into the settings and disable the magnifying button. The magnifying button and AF-ON button (which many folks configure for back button focusing) are pretty close to each other so you might have hit the magnifying button first then AF-ON bit later.
