10-09-2014 08:31 AM
Prior to having the AF points while looking through the viewfinder, I had he generic square focusing box,same as with the liveview one. Now I have those annoying red AF red dots. I'd like to revert to the earlier format/system, but do no know how. Can someone please explain?
For information I read over (and over he manual) and did a facory reset to no avail.
Thanks
Phoenix
10-09-2014 10:47 AM
What camera are you using?
Are you saying you have the "little red dots" in the viewfinder, or in live view. Those dots are your focus points when not using Live View (which uses a different, inferior focus system). They're actually quite important for using a dSLR, but you can choose to use them or not.
For the viewfinder you don't have a choice (assuming you're using a DSLR). You're looking at the actual image, through the lens. There are no graphics in there, other than the LED on the bottom that tell you your settings, and those AF points that are embedded in the screen. If you're using a camera with an electronic view finder that's not necessarily true, but seeing as how this is the EOS forum I'm going to assume you're using a dSLR, which do not have an electronic view finder.
If you're trying to change the settings in Live View I'll ahve to defer to someone else, I don't really use it. But I wouldn't be surprised if you can choose between the box and the dots.
10-09-2014 10:47 AM
10-09-2014 01:16 PM
I think I see what he's talking about. On some of the cameras with advanced AF (7D, 5D3, 70D(?) ...), you see dots or squares in the viewfinder, depending on whether you've selected a point or zone mode. And for fully automatic AF, you see a more or less rectangular figure. So, OP, I think you want to read in the manual about autofocus modes. (P. 70 in the 5D3 manual, p. 88 in the 7D manual, etc.)
10-09-2014 01:48 PM
Oh, the little squares around the AF points. Yes, you're probably right. I thought he was referring to the big focusing rectangle in LiveView.
10-09-2014 03:06 PM
10-09-2014 03:11 PM
