04-20-2025 02:16 PM
I’m using the R5 and I can record a video but it doesn’t save when I go to view it neither does it come up when I plug the SD cards in but when I go to format the card it does say something is there. Any ideas?
04-20-2025 04:46 PM
Often the video clips are saved to the CFexpress card if there is one in the camera. If you only have an SD card then in the camera it will be saved there. However some video resolutions and frame rates can only be saved to the CFexpress card.
04-20-2025 04:46 PM
04-20-2025 04:56 PM
thank you so much (:
