08-09-2024 09:26 PM - edited 08-09-2024 09:28 PM
I purchased a T2i several years ago and I used it a lot, life got busy and photography was pushed to the side. I'm starting to get back in to photography and was thinking about getting a new camera. I was thinking of buying the T7 due to budget, is the T7 a downgrade from the T2i? I have also thought about moving to the mirrorless.
Any advice would be great
08-09-2024 11:43 PM
The T7 is a performance upgrade, but it is also somewhat of a build quality downgrade. The T2i was a well built body.
Without knowing your budget it’s hard to advise you. Canon does offer Sales advice to customers looking to purchase an upgrade.
08-10-2024 12:27 AM
If you are prepared to consider mirrorless, then I would do so seriously. As Bill said, we can't give great advice without a $value to limit our enthusiasm. Depending on what lenses you have, if you want to keep them, then stick to one of the crop-sensor bodies: that would be R7, R10, R50. If you have only the kit lenses for the T2i, then look to getting an RF-S 18-150 lens kitted with the body of your choice. I would personally suggest the R10, as it has the best features for the investment. If you use EF or EF-S lenses you will need an EF-RF adapter.
