09-28-2020 04:53 PM - edited 09-29-2020 12:14 AM
Hello,
I'm faily new to the DSLR world. I got an used EOS 7D with an used EF-S 18-135mm lens. I've been using it while traveling/hiking for landscapes and portrait pictures. It is a pretty heavy camera and caryring it all day is tiring. I'm looking to upgrade the body to a ligher and newer model. I will buy a used one. I'm not looking to change the lens so I would like to be able to re-use it on the new body.
What body model would you recommanend for a beginer/intermediate user? I'm looking for something to fit with the EF-S 18-135mm lens. Is there a model that has proven reliable and there are plenty available on the used market? I'm not looking for advanced features but for something ligher weight and at a decent price, around $200.
Thank you!
09-28-2020 05:15 PM
How do you carry the lens? I used to get tired of carrying my camera, and found a camera strap fatiguing on hikes, not to mention the bump hazard that comes with having a camera swinging from your neck or shoulder. I also wasn't a fan of having a hard camera body bouncing off of my hip for a few hours, either.
So, I invested in a Lowepro Toploader Camer Holster. They come in a varying sizes. Some are designed for pro bodies, or bodies with a grip, and some are designed for bodies without a grip. In each of those types, they come in varying depths for lenses of different sizes. Now, I can hike with two free hands, and not worry about my camera bouncing around.
09-28-2020 05:27 PM
The 7D is a 2009 model. Any Rebel T4i or later will be newer and lighter.
The 7D is a more specialized camera than a Rebel, but it sounds like that is not important to you.
Check the Canon eStore for refurb models.
09-29-2020 12:58 PM
@jrhoffman75 wrote:The 7D is a 2009 model. Any Rebel T4i or later will be newer and lighter.
I don't disagree with John's points, but I will point out that:
- The 7D was, for its time, one of the best cameras Canon ever made; and ...
- No Tni has AFMA. But the 7D does; and unless you confine youself to "L" lenses, there may be times when you need it.
09-29-2020 03:58 PM
Bob,
I will add to your excellent response that even with L series lenses, AF microadjustment is often needed for perfect AF. It only takes a few minutes but the results are worthwhile and when I acquire a new lens or body I always check and adjust if needed before shooting anything important so some of the first images from any of my new gear are a series of boring photos with a target surrounded by the lawn 🙂 And several of my L series primes have required a slight (never more than 4 point offset) adjustment with a particular body. They are certainly close enough to use out of the box but since I generally use fast lens that are wide open most of the time, close isn't quite good enough 🙂
I use a slightly modified version of Canon's suggested procedure and shoot a series of three shots at 0 offset and then three shots each with offsets on the positive and negative adjustment sides in one session and then closely check them on the computer. From this series, I can quickly either choose the proper point or know exactly what adjustment points to shoot a second run using as the boundary adjustments. If the lens is one that I might use a 1.4X with, I will also do the shots for it in the initial run. This process takes 10 minutes or less to perfectly dial in a lens.
Rodger
09-29-2020 04:16 PM
OP said " It is a pretty heavy camera and caryring it all day is tiring. I'm looking to upgrade the body to a ligher and newer model."
The 7D is a great camera. While I wouldn't go in that direction it seems to be what the OP wants.
Like Rodger I also check my focus on a new camera/lens combination.
I suspect that the type of lenses that most Rebel owners are using (f/3.5 or smaller apertures) have enough depth of field that the minor AFMA adjustments that we would make to our L lenses are encompassed in the DOF along with the less critical output.
09-30-2020 10:13 AM
"I suspect that the type of lenses that most Rebel owners are using (f/3.5 or smaller apertures) have enough depth of field that the minor AFMA adjustments that we would make to our L lenses are encompassed in the DOF ..."
Exactly why the Rebel line doesn't offer it. I probably have had more than a hundred lenses in the past few years since my retirement and I can safely and confidently say most lenses, especially "L" lenses, do not need AFMA. That is what I have seen in my experience anyway. Two things about AFMA, one it is easy to screw things up. And, two it does not make a lens, any lens, sharper. A lens is as sharp as it will ever be the day it leaves the factory.
09-30-2020 10:17 AM
" I'm not looking for advanced features but for something ligher weight and at a decent price, around $200."
You, my friend, are going to be disappointed! A camera with better and more advanced featuers than a 7D has, all for $200 bucks? Not likely in this world. Finding something "lighter weight" will be easy. Besting a 7D will not.
09-30-2020 10:28 AM
09-30-2020 11:39 AM
" I'm not looking for advanced features ..."
I am sorry. I misread your requirement. However, the $200 dollar limit still is going to make it tough unless you settle for another older camera. The 7D is a very capable camera that hsd only weight going against it. That is because it is a magnesium body. The Rebels like the T4i which is about $200 used will be plastic. Agreed much lighter but less well built for sure.
