02-04-2019
01:04 AM
02:06 PM
I have a Canon Rebel T6 and I have done everything from downloading multiple apps, different mobile devices, and etc. Nothing seems to work, I am having trouble with videos. Everytime I try to download a video onto my phone with the Canon Connect app it just tells me "Movie Format Not Supported" Please I need information ASAP.
08-30-2020 08:19 AM
@BWedding wrote:I'm not sure why this is marked as a solution. Connecting via NFC still fails to import MOV files to Android.
I've even installed VLC Player, which plays MOV files and that doesn't help. The app refuses to import MOV regardless.
The following is from the app information found at Google Play Store HERE:
-Compatible File Types
JPEG、MP4、MOV
・Importing original RAW files is not supported (RAW files are resized to JPEG).
・MOV files and 8K movie files shot with EOS cameras cannot be saved.
・HEIF (10 bit) and RAW movie files shot with compatible cameras cannot be saved.
・AVCHD files shot with Camcorder cannot be saved.
08-31-2020 02:38 PM
The "solution" should probably clearly state that Android will not import MOV files no matter what. And while it may not be broken, 1/2 your market is disenfranchised.
08-31-2020 05:47 PM - edited 08-31-2020 05:48 PM
@BWedding wrote:The "solution" should probably clearly state that Android will not import MOV files no matter what. And while it may not be broken, 1/2 your market is disenfranchised.
Actually, the "solution" should probably remind users that Android does not MP4 files. You need special apps.
08-31-2020 07:46 PM - edited 08-31-2020 07:46 PM
WHAT?? NO special apps needed on my Pixel 3 XL with Android v10.
08-31-2020 11:57 PM
Here's the thing. It's not Android's fault. I can download multiple apps to play MOV files, such as VLC. It doesn't matter if I've downloaded those or not. The application sees Android and throws an error and will not download regardless.
Look, I'm a software engineer. The right behavior is to download the file, no matter the extension. Let the end user deal with the issue once they have the file. It's not correct to simply refuse to download it because it is Android.
09-01-2020 05:27 AM - edited 09-01-2020 05:28 AM
@BWedding wrote:Here's the thing. It's not Android's fault. I can download multiple apps to play MOV files, such as VLC. It doesn't matter if I've downloaded those or not. The application sees Android and throws an error and will not download regardless.
Sorry, but you are incorrect. Android does not support MP4. If it did, then this would not be an issue. Would it?
Camera manufacturers cannot rely on a user supplied, third party application to make the camera manufacturers' applications fully functional. If the OS platform does not support a common file format, then that OS platform is flawed.
09-01-2020 05:30 AM
What app do you use to play MP4 files? What app did you install?
09-01-2020 12:57 PM - edited 09-01-2020 01:52 PM
I did not need to install an app to play MP4 movie files on my Pixel 3 XL. I use the native, built-in Google Photos to play MP4 movie files. Google Photos doesn't have a lot of fancy controls, but it gets the job done!
You must be an iPhone user that knows nothing about Android. ![]()
09-01-2020 01:56 PM
That's nice. They're finally catching up with the industry, a day late and a dollar short.
I stand by what I said earlier. Try a web search for "how to play MP4 on Android", and look at all the hits you get.
09-01-2020 02:11 PM
Google Photos will play MOV files (not sure why you keep saying MP4 which is not what a T6 produces), right out of the box on my Android 10 Pixel 2XL.
I actually just tested it. I transferred via USB, a .MOV file created by my T6. I navigated to it with File Manager and played it with Google Photos and VLC. Then, just in case VLC had installed codecs, I uninstalled it and did it again.
