05-24-2023 12:15 AM
I just bought the T8i, and for the most part I'm happy with it, except I'd like to get sharper images. I'm sure the camera is capable but I seem to be running into issues. SO, I tried setting up a calibration wedge and my lens shows that the 20cm to the back is sharper than the 20cm to the front
. I can't find a setting to correct this. Am I SOL? Should I be sending the body back to Canon for re-tooling? How do I avoid this problem with other lenses I'll have down the line? I'm using tripods and remote shutter trigger, so it's as stable as it's gonna be (At least until I get a better tripod) but it's pretty solid. (No extension used on the tripod) Help!
05-24-2023 01:44 AM
I'm pretty sure that the T8i does not have an AutoFocus MicroAdjustment (AFMA) feature, so I'm not sure how you would go about having that fine tuned.
Which lens are you using, f/stop, and what is the distance to the target?
Newton
05-24-2023 01:47 AM
The Rebel Series of DSLRs does offer the lens focus calibration feature. At best, you could send the camera and lens to Canon to check focusing. But, I am not certain if micro-adjustments are possible on a Rebel body.
05-24-2023 08:36 AM
There is no in-camera adjustment possible with Rebels. Is this your only lens? If not, do other lenses have the same discrepancy.
You can send to body and lens to Canon and they will adjust both to factory specs.
05-24-2023 09:05 AM - edited 05-24-2023 09:05 AM
Oi. Not the news I wanted to hear. But thanks y'all. Any idea what the turn-around is for something like that? ? I do have the 55-200 as well, but haven't tried to shoot the calibration tool just yet. I'll try it later tonight and see if that's an issue. Thanks again.
05-24-2023 09:25 AM
I’ve sent a number of items to Canon for cleaning and adjustments. Turnaround was less than two weeks door to door.
05-24-2023 09:32 AM
Before you send it in, it'd be helpful to know which lens you're using, and the exact settings, as this could be absolutely normal for the shooting conditions.
You might also try the test again in really good lighting without distractions in the background of the shot.
05-24-2023 09:46 AM
My first quality digital camera was a 1D Mark II I bought in 2005 and it was built before Canon included micro focus calibration by lens in the body. I sent it and several L series lenses to Canon for calibration, at that time turn around was just over a week.
Pretty much all of my camera lenses are wide aperture and when I get a new body or lens, I immediately do a micro-focus calibration with the new gear. IF the AF calibration is far enough off to impact your typical photography, then it is worthwhile to have the calibration done by Canon.
Rodger
05-24-2023 10:04 AM
Does it happen in Live View?
05-24-2023 04:50 PM - edited 05-24-2023 05:00 PM
Previous responses are correct. There is no Micro Adjustment feature on the T8i or any of the other Rebel (or "Kiss" or EOS xxxD, xxxxD) series cameras. That feature is only found on the EOS xxD and xD series DSLRs. (It is also not a feature or even necessary on any of the mirrorless cameras.)
Honestly, I would forget about it. Throw that focus calibration tool in a drawer, go shoot and enjoy your camera.
You still haven't told us what lens you were testing for the sample photo. Maybe the EF-S 18-55mm? Or perhaps the EF-S 18-135mm? Those and the EF-S 55-250mm simply aren't critical of precision focus, the way large aperture lenses are. At "normal" shooting distances with those lenses the natural depth of field of f/3.5 to f/5.6 lens apertures will obscure any minor focus error.
In fact, you probably should try stopping down a little if sharp images are your goal. Most lenses are sharpest a stop or so smaller than their max aperture. And that stopping down will further increase your depth of field, making focus precision even less crucial.
By all means test your lenses.... go shoot a highly detailed, flat surface like a weathered fence or brick wall... keep parallel to the subject... shoot at different focal lengths and apertures to "learn" where you're lenses perform best.
Other things that can help sharpness...
