01-24-2026
08:44 PM
10:56 PM
Tiffany
Let's assume I'm in Manual with Auto ISO.
The scene is stationary, so there's no danger of motion blur.
I meter the scene and it hits 0. I'm properly exposed, but I think the picture is a little too dark or too light for my tastes.
My focal length is around 50 or 60mm, and my shutter speed is up around 1/250, so I've got some wiggle room before I risk camera shake.
My ISO is around 320-400, so I'm not too much danger of introducing objectionable noise.
The conventional wisdom to darken or lighten my picture by 1/3 or 2/3 of a stop is to use exposure compensation, whIch In Manual plus Auto ISO is going to raise or lower my ISO.
Why should I do that instead of just slowing or speeding up my shutter speed by 1/3 or 2/3rds of a stop?
On my camera (a T8i), using exposure compensation requires two simultaneous actions - pressing the set button whiie turning the main control wheel.
Changing the shutter speed only requires the one action of turning the control wheel.
Steve Thomas
01-25-2026 02:37 PM - edited 01-25-2026 02:39 PM
I expressed the same puzzlement back at the end of 2025 on a thread entitled, "T8i ISO too high".
Back then, I wrote,
12-31-2025 12:50 PM
"SignifDigits,
In researching this issue, I discovered that it is not an uncommon phenomenon.
If you do a Google search for Overexposure and Auto ISO, you see entry after entry of people who experience the same thing. I even read one person who said that with Auto anything, Canon lands on the side of caution and has a tendency to lighten things up as opposed to underexposing."
Steve Thomas
01-25-2026 04:35 PM
Despite what metering in a DSLR shows, the cameras seem to have +1/3 Ev of compensation baked into them.
This behavior does not seem to be used in the full frame R Series bodies. Dialing the small amount of negative compensation results in a photo that looks a little under exposed.
01-26-2026 10:23 AM
"There’s even a name for it. ETTR."
That's not "baked" in unless you the operator bake it.
01-26-2026 10:44 AM
I know I have seen him discuss it elsewhere, but Ken Rockwell seems to dial in a -1/3 ev compensation on his Canon DSLRs:
https://www.kenrockwell.com/trips/2012-04-slo/index.htm
