‎01-13-2026
07:47 PM
‎01-14-2026
08:48 AM
I shoot still and video all day long every day. I went to the r1 from an r3 in which I never once had this issue. I use 512gb CF Express cards and less than 200 gb used I get a message in my viewfinder stating "number of clips in card 1 and card 2 already at maximum"....and will NOT allow me to video any more. It will however allow stills. My camera is set up to record both the stills and video to each card so I have an exact back up. It's very frustrating to not be able to use the entire 512 gb. No one has been able to help with this issue. Hopefully someone on here can. Thanks in advance..
‎01-14-2026 12:21 PM
If the message says that the maximum number of files is at the maximum, then storage space probably isn’t the problem. How many video clip files do you have in the current folder. You could be limited to 99.
‎01-14-2026 01:14 PM
Waddizzle is correct. The total number of clips is actually 999.
Canon : Product Manual : EOS R1 : Movie Clip Numbering https://share.google/5YVfCfZcCdQBkU8i4
‎01-25-2026 11:21 AM
So my remedy to this is what? I read all the information on the link but do I have to manually reset back to 001 every time? Do I need to be set on continuous or auto reset? I never had this issue at all with my r3....has me totally baffled and confused. Wish I was smarter....lol
‎01-25-2026 11:27 AM
“How many video clip files do you have in the current folder?’
How many files? I am guessing that you should create a new folder.
‎01-25-2026 12:14 PM
I can see how that would be a frustrating block in your workflow, especially when your CFexpress cards show plenty of available capacity.
This behavior usually indicates that the camera has reached its maximum file indexing limit. Even on a flagship like the EOS R1, the system typically follows the DCF (Design rule for Camera File system) standard, which caps folders at 9,999 items. If you are shooting high-speed bursts or numerous short video clips, you can hit this "Number of Clips" ceiling even if the card is only half full.
Best-effort steps to clear the block:
Create a New Folder: In the Wrench menu, select [Select folder] and create a new one to reset the 9,999 count for that directory.
Low-Level Format: If you have already backed up your data, perform a low-level format in-camera to refresh the card's file allocation table.
Support: If you get stuck, support is available weekdays at 1-800-OK-CANON (1-800-652-2666).
Canon Professional Services (CPS): If you are a CPS member, you have access to 24/7 priority support. Please log into your account at http://canon.us/cps to access your dedicated hotline and ensure your R1 workflow is restored as quickly as possible.
‎01-25-2026 12:44 PM
I'd like to have clarification too. 🤔 In the link I provided the R1 manual states that the clip limit is 999 per folder. I searched the manual for 9,999 but nothing came up. So does this mean the clip limit per folder is 999 and the OS limit is 9,999?
Thanks
‎01-25-2026 01:36 PM
If the file count has reached the folder limit, I would expect it to automatically create a new folder so it can keep going. That should be the default behavior, unless it’s been disabled.
‎01-25-2026 01:52 PM
Hello,
It isn't completely obvious, so let me try to break it down. To address shadowsports' point regarding the 9,999 limit: while it isn't always listed directly next to the error code in the manual, the specific behavior is documented in the EOS R1 Advanced User Guide under the "File Numbering" (Set-up Menu) section. It explicitly states: "When the file number in a folder reaches 9999, the next file number will be 0001 in a new folder."
The "Maximum" error message triggers when the camera is unable to perform that "new folder" handoff. This can happen for a few reasons:
Folder 999: If the card has reached folder number 999, the DCIM specification is effectively "maxed out" and a format is required. To resolve this, try creating a new folder manually in the Setup (Wrench) Menu by selecting Folder settings. If this works, it confirms the previous folder was just at its limit.
Indexing Conflict: If you are recording to two slots and one card has a conflicting folder structure, the R1 may stop recording to prevent a file-naming collision. To resolve indexing conflicts, offload your clips and perform a low-level format in-camera. This is the "gold standard" fix for any indexing errors.
File Numbering Settings: If numbering is set in a way that prevents automatic folder creation, the camera will hard-stop at 9,999. To fix this, ensure your file numbering is set to [Continuous] in the Setup (Wrench) Menu under Numbering. This allows the camera to roll over into new folders seamlessly instead of stopping at 9,999.
Step-by-Step:
Select File numbering.
Set the item.
Caution
If you've tried these steps and the R1 is still throwing the error prematurely, we definitely want to hear about it at 1-800-OK-CANON (1-800-652-2666). Our technical team can then document the behavior and see if it requires a deeper look.
https://cam.start.canon/en/C018/manual/html/UG-07_Set-up_0050.html
‎01-25-2026 05:23 PM
Thanks, Stephen. Some great stuff to know.
