05-07-2020 03:05 PM
Hi guys/gals. I've had this camera about a year and now want to use the wifi function. I've read, watched videos and I cannot connect. I do get the blue wifi enable LED flashing bur cannot connect to my network. It's asking for a password and the password is the encryption key but on my menu the encryption key reads AES and that does not work. I was never asked to enter a camera name or led to that page. I've also tried resetting the camera to factory settings and reinstalled the app but nothing seems to work. Can anyone help?
05-09-2020 12:39 PM
Well I called Canon and got the problem resolved. It appears that Set 1 had to be deleted before I could proceed. He talked me through that and everything worked but still did not get a screen that allows me to name the camera but that was already put in for me as Canon Rebel T6i so I guess no real reason to change to any specific name. In the future I will not have to go through all that again because the encryption code will appear.
05-07-2020 07:09 PM
Did you try the password for your WiFi router?
05-07-2020 09:33 PM
JamesEmory,
IMPORTANTIf [: Wi-Fi/NFC] is set to [Enable], the camera cannot be connected to a computer. Set [Wi-Fi/NFC] to [Disable], then reconnect the camera to a computer with an interface cable.
- Windows 8: Right-click on the [Start] screen and click on [All apps] displayed at the bottom right of the screen to display the [Apps] screen. Then, click [EOS Utility].
- Windows 8.1: Click [↓]on the bottom left side of the [Start] screen to display the [Apps] screen, and then click [EOS Utility].
- Mac OS X: Click the [EOS Utility] icon on the Dock.
05-08-2020 11:43 AM
No, they don't want that, they want the encryption number which I do not get like they show in the video. I get AES for a number and that doesn't work.
05-08-2020 11:46 AM
Thanks for your very informative reply but I want to connect to my iPhone so I can use the iPhone as a wireless remote. The learning videos I watched show no interrface cable being used between the phone and camera.
05-08-2020 08:09 PM
Does this help:
https://ditchauto.com/how-to-use-wi-fi-nfc-on-canon-rebel-t6i/
05-08-2020 08:24 PM
JamesEmory,
05-09-2020 11:24 AM
This is my problem. When I get to this step I do not get this screen.
The camera goes back to this screen.
05-09-2020 11:28 AM
@JamesEmory wrote:This is my problem. When I get to this step I do not get this screen.
And you performed this step:
05-09-2020 11:38 AM
Yes, I pressed the right arrow and pressed set and then the screeen returns to the beginning. I have no screen that allows me to create a nickname. Why does everything have to be so complicated. I bought the camera so I wouldn't have to buy a remote.
