08-06-2019 01:53 PM
My T6 will not produce any images when using live view, but will when using the viewfinder. AND - this problem ONLY occurs when using the 18-55mm lens, not the 70-300mm lens. What gives???
08-09-2019 06:59 PM
“Does the 18-55 autofocus when not in live view?”
How do you do that test? You do the following.
“Ask your friend to try the camera outdoors on a sunny day. Aim the camera at something lit up by the sun. Do not stand too close the subject. I would say a distance of 20 feet is a good test.”
I think the OP has already reported that it does autofocus in the viewfinder.
04-09-2024 11:33 AM
Having same issue with my wife's T6 Rebel and the 18-55 lens. If using the viewfinder, autofocus works with a half press and you can take photos with a full press. If you are using the rear LCD instead, any press of the shutter button (half or full) will trigger the shutter but no image is saved.
04-09-2024 11:39 AM
Does live view work in manual mode as in the OP?
04-09-2024 01:06 PM
It almost sounds like your 18-55 may have some kind of damage to its lens mount and is not communicating with your camera, and I am not a serious photographer.
Steve Thomas
