T5i repair help needed...
ThatJeepGuy
Hi, I have a T5i and last night the top of the mode selection wheel popped off. What adhesive would work best for reattaching this piece?
15 REPLIES 15
ThatJeepGuy
I can see how they would be easily lost. Fortunately mine popped off on my passenger seat.
ThatJeepGuy
I was going to go with some RTV that I used for securing small plastic parts on my motorcycle but I opted for the GE Advanced Silicone. I will leave updates as time goes by as to how well it works.
Best of luck to you!
The silicone will probably be OK but you have to be careful with it around electrical circuits if it is of the type that outgasses acetic acid during the cure (that strong vinegar smell you get while it is curing).
Acetic acid is corrosive to copper, zinc, brass, etc. which are materials often used in various electrical connectors and switches.  Once cured, it isn't a problem but what you want to avoid is a situation where the fumes from acetic acid will be trapped and contained around electrical contacts, unprotected circuit board traces, etc.
Rodger
stevet1
Hello from a fellow Jeepster.
Steve Thomas
"Hello from a fellow Jeepster.
Steve Thomas"
My son is a 'jeepster' no I mean a Jeep gonzo!  Smiley Happy
EOS 1DX and many lenses.
