05-30-2016 11:38 AM - edited 05-30-2016 11:42 AM
Hello all, while doing a google search on my issues with my T5i I found this forum. I read through the "Camera saying busy and won't take pictures" thread and decided my issues while similar isn't quite the same. I'm very hopeful someone can help me.
I shoot in manual/raw format and normally use a Rokinon 14mm lens that is 100% manual (no auto focus), the camera is also in manual focus mode.
I noticed the other night while shooting some Milky Way shots that I could not take consecutive pictures without pressing the playback button first then pressing the shutter button. The first press of the shutter button works correctly but the second press and so on does not, I found this quite odd and investigated further. While pressing the shutter button the "Q" in the lower left of the screen would highlight coinciding with the shutter button being depressed but the shutter would not activate. I then turn on the touch shutter and it worked flawlessly. I plugged in my Vello intervalometer and tried it, same result as using the shutter button itself, I have to press playback in order for the shutter to fire. I though it was a lens issue so I swapped lenses to my kit lens (18-55mm stm) and same problem, even in auto focus modes on the lens and camera. I also cleaned the lens contacts and inspected for visual damages. At this point it doesn't appear to be a lens issue. I then updated the firmware to Ver 1.1.4 & reset the setting to factory defaults all to no avail. The issues also exists in all menu functions (Auto,Av,M,Tv, etc).
While expermenting I found out that if I press the DOF button (below the lens release) between shutter button presses the shutter functions every time without failure.
I forgot to include the memory card is a Sandisk Extreme Plus 32gb
05-30-2016 12:43 PM
@nyttrain5150 wrote:Hello all, while doing a google search on my issues with my T5i I found this forum. I read through the "Camera saying busy and won't take pictures" thread and decided my issues while similar isn't quite the same. I'm very hopeful someone can help me.
Try a differnt memory card.
05-30-2016 12:46 PM
I tried several cards all wit hthe same results.
05-30-2016 01:01 PM
05-30-2016 01:05 PM
I tried that as well and still no change.
05-30-2016 01:27 PM
I think a phone call to Canon technical support is in order.
05-30-2016 01:49 PM
@nyttrain5150 wrote:I tried several cards all wit hthe same results.
"I noticed the other night while shooting some Milky Way shots that I could not take consecutive pictures without pressing the playback button first then pressing the shutter button."
Did you try reformatting your card(s)? Turning off "Long Exposure Compensation"? Turning off "High ISO Compensation? Are you using your intervalometer in Bulb mode? If all that fails, contact Canon Support.
05-30-2016 02:07 PM
05-30-2016 02:17 PM
I reformatted the cards, reset the camera to factory defaul settings, and when using the intervalometer I was in bulb mode. I do think I will be calling Canon Support tomorrow.
Okay. Just be aware that Long Exposure Compensation can take as much time as your original exposure. If you are using image stacking software, then I don't see any need to use any of the camera's built-in noise compensation features.
05-30-2016 02:50 PM
