T5i firmware update one by one?
swordsx48
Hi, hope all are well!
Aiming to update the T5i from 1.0.1 to the latest 1.1.5 but I'm getting the update error no file found.
I noticed the 1.1.5 page said it works for versions 1.1.4.
Do I need to walk it up one by one?
Or maybe try the EOS utility?
Thanks in advance!!
7 REPLIES 7
Peter
You install the latest firmware. No need to install older ones.
Indeed, firmware updates are cumulative.  Get the most recent version and you'll have the functionality or fixes included with each subsequent update.
jrhoffman75
Thanks in advance!!
Download the appropriate OS version of these files and follow the instructions step by step. A common problem is that the .fir file isn't placed in the root directory of the card.
swordsx48
Got it solved guys! Thanks for the help!
You wouldn't believe it - there's a T3i here and a T5i. The T3i has always had a hanging lens cover. Someone must have switched them at some point. So the attempts were made on the T3i instead of the T5i.
Got it all set today! Thanks!
Man, can you imagine how stupid it would be if updates needed to be applied one by one and only could be done on the most recent version of firmware/software? I think I've seen it at some point with some software or another, but at least it was an automated process. Thank god it's generally not like that and this one was cumulative!
Peace n luv to all
Hello. I also have a EOD Rebel T5i and was looking to download the 1.1.5 firware version. On my camera, I currently have firmware version 1.1.1, and my computer is running macOS Sonoma v14. The only version the Canon website is giving me for download is version 2.1.18 EOS Webcam Utility Pro 2.1.18 (macOS). I downloaded the file to my SD card, hoping the camera would detect a .FIR file, but that did not work. Did Canon stop supporting the T5i? What am doing wrong? Any feedback would be greatly appreciated. Thank you.
At the Canon Support site, even though you are on a Mac, change the OS to Windows 10. You will see the 1.1.5 firmware update. It will be a ZIP file, but your Mac will open it and allow you to extract the *.FIR file to be placed on your SD card. There is also a TXT file with install instructions.
Newton
That worked! Thank you so much. 😊
