T5i - Video recording creates a white dot on the video
Delta1Seven
When I record videos, there is a small white dot (pixel size?) that is in every video in the same location.
This issue only happens in video mode, not in any of the photo modes. At first I thought it was a dead/stuck pixel, but wouldn't it display in photos as well?
Here is a video showing the issue. It's the white dot in the lower part of the frame, just left of the center.
https://youtu.be/7oi5tcb2wOM
You may need to go full screen to see it.
1 REPLY 1
Mykolas
Hi Delta1Seven!
Welcome to the Canon Forum.
What this looks like is a stuck pixel or a hot pixel.  This can happen if the image sensor heats up after recording for a while.  Does the pixel appear when you immediately start recording after the camera has been sitting powered off for a while, such as overnight, or does it appear all the time?
