EOS R50 - Choppy video over HDMI
kfc1985
We have two new R50s in our podcast studio going into a Rode caster video via HDMI. For local recording, they are great, but once we need to do a video interview (Zoom, Riverside or Streamyard), they get very choppy. I tried using Elgato Camlinks and got the same outcome. I can go USB and use the Canon webcam app, and the video quality is fine, other than being maxed out at 720p.
Cameras are set to 30FPS at 1080p, and HDMI is set to AUTO.
Can anyone help?
5 REPLIES 5
Hazel_T
Hi kfc1985,
I'm sorry to hear you are getting choppy HDMI output on your EOS R50 camera bodies. There are some things to check with his. The first would be to double check that the devices and programs the video is being output to are set to the same frame rate as the camera. If you are in the US typically devices would be using the NTSC standard frame rates like 24 fps. If there is a mismatch between the camera output and the frame rate of the software or device the video is being output to that can cause choppiness.
Another thing to double check would be to try replacing he HDMI cables. Since the outputs through USB are clear that indicates the ports on the camera are working correctly. The USB and HDMI ports on the camera are routed through the same portion of the PCB, so typically if one was malfunctioning we would expect them both to malfunction.
One other thing to double check is that if you have an external monitor we would recommend trying to plug a camera directly into it and check to see if the live output is choppy. That could help narrow down where the choppiness might be originating from.
I've tried different frame rates, new cables, and nothing works. It’s so weird that two cameras, with two different cables, would have the same issue. Streaming is the only problem, unless I stream directly through the Rodecaster app, then it’s smooth. I get the same choppy results from Elgato CamLink and any other capture card, which makes me think it’s some setting within the camera, but I cannot figure it out.
How are the cameras being powered?
They are on A/C power.
“ They are on A/C power. “
That’s a potential problem.  Are you using the Canon brand power adapter?
I also suggest testing it on battery power.  Just a test.
