11-06-2017 05:19 PM
I have an EOS T5I and a 430EX-IIIRT Flash but cannot get the Flash to fire remotely.
I have selected Easywireless Flash on the camera, put the flash into Slave mode, and made sure they are on the same channel, but cannot get the Flash to fire remotely.
Wondering if anyone else has had these issues and if a solution was found?
11-06-2017 06:02 PM
@Charliemora2 wrote:I have an EOS T5I and a 430EX-IIIRT Flash but cannot get the Flash to fire remotely.
1. This works only with the creative modes (Av, Tv, M).
2. You need to pop the built-in flash up
3. Your 430EX-III supports two slave modes - one optical and the other Radio. The T5i can only do optical, so make sure the slave mode on the flash has the lightning bolt symbol and not the antenna symbol with the circles.
11-06-2017 06:40 PM
You forgot "P" 8^)
11-06-2017 06:45 PM
Wondering if anyone else has had these issues and if a solution was found?1. This works only with the creative modes (Av, Tv, M).
That is a Yes for all 3 questions, but still cannot get the Remote Flash to fire
11-06-2017 06:53 PM
Optical means that the camera and remote flash need to have a line of sight.
How far away is the remote, relative to the camera?
11-06-2017 06:58 PM
I tried different distances from 2 to 6 feet, while I was trying to get it to work, and I had the front sensor od the Flash facing the camera with the pop up flash up. The Pop up flash would always fire, but the Speedlight would not trigger.
11-06-2017 07:31 PM
I’ll assume that you have it configured properly. Sounds like you know what to do to make it work. From what you have described, it sounds like the remote should fire. If the flash does not work when mounted on the camera, then there could be problem with the flash.
11-06-2017 11:50 PM
Can you take a picture of the camera flash menu and the flash menu and post them here. We can then can tell if something is amiss...
If you have set everything correctly it should work unless the flash is broken which I doubt is the case.
11-07-2017 08:13 AM
11-07-2017 08:56 AM
