04-10-2016 11:15 AM
Hello all, new member of the canon community and also new to photography. I started off using a Minolta Maxxum 5xi (35mm SLR and still planning on using it) and recently acquired a Canon Digital Rebel XTI from my Aunt.
I took up photography as a hobby and am new, still learning the ropes.
After doing much research, I decided to save up for the T5. The T5i looks attractive, but I cannot for the life of me justify the extra $100 or so for the T5i.
Which one should I get?
04-10-2016 06:22 PM
IMHO, I would spring for the T5i. Even the T6i if you can work it out. When you get the top of the line in almost anything it stays pertinent longer.
04-10-2016 06:41 PM
04-11-2016 09:00 AM
It looks like you already made up your mind. I would go with your gut feelings. The T5 is certainly a capable camera and does a fine job. The main thing is the sensor and both have the same sensor.
One word though, in anything electronic, which is where cameras belong, you are not the controlling force that obsoletes them. That is largely out of our control. If you read my sig you will notice I still use obsolete, discontinued cameras but they were the top of the line at one point. They are still relevant today and will be for some time.
Good luck with your new T5. ![]()
04-11-2016 10:21 AM
@ebiggs1 wrote:It looks like you already made up your mind. I would go with your gut feelings. The T5 is certainly a capable camera and does a fine job. The main thing is the sensor and both have the same sensor.
All very true. But if you're trying to select a camera for the long haul, I'm inclined to think that picking from a higher line may be a better bet than picking the top of a lower line. I.e., a refurb 7D or 70D (both recently rendered obsolete and therefore susceptible to price softness) may be a better value in the long run than the T5i for someone in the OP's situation.
04-11-2016 10:54 AM
Bob from Boston,
Totally agree.
04-11-2016 04:08 PM
@Misc_Photo wrote:Hello all, new member of the canon community and also new to photography. I started off using a Minolta Maxxum 5xi (35mm SLR and still planning on using it) and recently acquired a Canon Digital Rebel XTI from my Aunt.
save your money you will see no difference between your Canon Rebel XTI EOS 400D and Rebel T5 Compared imho
if you have your heart set on Rebel T5 1200D might I recommend Canon Refurbished $249.99 to $309.98 as of today
several others Canon models under $500
The SL1 100D has slightly better low light specs according to DxOMark than the 1200D which has slighty better specs than the T5i 700D
With a kit you at least get lens or lenses for immediate use, albeit they are low end Canon lenses
Canon Refurbished cameras prices vary widely over just a month or two
04-11-2016 04:18 PM
several others Canon models under $500The SL1 100D has slightly better low light specs according to DxOMark than the 1200D which has slighty better specs than the T5i 700D
I'll have to look into refurbed when the time comes, still saving the cash 😉
04-11-2016 06:53 PM
save your money you will see no difference between your Canon Rebel XTI EOS 400D and Rebel T5 ...
I don't think I believe that comparison. My wife and I had XTi's, and she has a T2i. The T2i is noticeably superior in every respect; my only beef with it was that it didn't take CF cards. One has to assume that they made at least some progress between the T2i and the T5, which means it has to outclass the relatively ancient XTi.
I still have my XTi. It's the camera I take to the beach on windy days.
04-12-2016 02:03 AM - edited 04-12-2016 02:05 AM
Bob from Boston,
"I don't think I believe that comparison."
Totally agree. Again!
"... according to DxOMark ..." And here-in lies the problem.
At least the refurb suggestion was good. ![]()
