09-29-2019 02:23 PM
I recently discovered that the flash on my device isn't working. Every time I attempt to use it I receive the following message:
Error 05: The built in flash could not be raised. Turn the camera off and on again. If anyone has any suggestions on how to fix this, I would greatly appreciated it. I have turned it off and on again so many time and still receive the same message.
09-29-2019 03:36 PM
Flash may be stuck or jammed.
Press the flash popup button and carefully try to raise the flash by using a credit card as a pry device. If it doesn't pop up that way (meaning it is likely jammed vs stuck) it will need repair.
09-30-2019 01:01 PM
"Flash may be stuck or jammed."
Unless you hit it while it was up it is more likely just gummed up. I use m y fingernail to "help" it up. The camera only tries for a short time so you must do it quickly. If you are successful try to clean the mech with some alcohol.
09-30-2019 01:22 PM
This You Tube might help you https://www.youtube.com/watch?v=av3t5RNY5PY
09-30-2019 06:42 PM
09-30-2019 09:22 PM
