12-13-2016 04:42 PM
Hi everyone. So I've had a T3i for a few years now. It's been great. For the last year I've been using a Samsung 128GB SD Card, which has also been great. Last week I turned my camera on like normal, and went to take pictures like I have been for years. The second picture I took, the camera froze up. I couldn't do anything. I had to remove the battery just to get it to shut off. Then it wouldn't turn on anymore. I tried and tried and tried and It wouldn't turn on. I took the SD Card out and removed the battery. When I put the battery back in it turned on. So I put the SD card back in and NOTHING! Then I put the SD card into my computer. SD Card is unreadable. So I tried to format it. It won't format. I can't do anything with it. I've since had certified tech people try their hands at the SD Card. It is locked up good. I tried a different SD Card, a 16GB. After playing around for about 5 minutes I got it to work. Then I tried a 32GB card. Nothing! I tried everything but it won't turn on with that card. So then I put that card in my computer. Same thing, it is locked up! This camera is destroying my SD Cards. I've tried a 2GB and a 4GB and an old 512MB card. Those all work. It seems like anything bigger than a 16GB won't work and gets destroyed! Please, if anyone can help me I would be so appreciative!
12-14-2016 05:13 AM
12-14-2016 08:26 AM
No I have not. But at this point I'm willing to try anything. I'll try it tonight and let you know if it worked. Thanks
12-14-2016 09:27 AM
03-10-2020
06:38 AM
09:09 AM
Stephen
Did you ever manage to solve this issue?
I had my T3i's DC/DC PCB Assembly [Mod note: Removed link per forum guidelines.] replaced because the service centre technician believed it was preventing the camera from turning on, while it was probably the camera just freezing up. (I also observed that the camera needs to be turned off with the battery out for a while before it can be switched on again... and before it destroys another card.)
I know it's a long shot after nearly four years since the original post...
03-10-2020 09:32 AM
This thread is 4 years old.
03-10-2020 10:54 AM - edited 03-10-2020 10:54 AM
I realise that, I also mention in my post that I know it's a long shot that OP would reply... But it's also the only forum post I found when searching on Google and it made sense to continue it as it was never resolved and it's the same issue. It makes it more likely for someone else with the same issue to find it in future.
Anyway, I will probably try replacing the SD card reader component - I was just hoping that maybe soemeone with more knowledge of how these cameras operate could point me in the right direction.
03-10-2020 10:55 AM
@jonasbxl wrote:Did you ever manage to solve this issue?
What you describe could be a symptom of the camera overheating (although that's not something we commonly see reported in a T3i), Maybe that's why the technician replaced the PC board.
03-10-2020 11:07 AM
That's very interesting, thanks! It definitely explains why the technician would replace that part first - it also looked like the issue was fixed (until the next card was destroyed by the camera).
I thought the freezing up was maybe caused by the software (possibly due to an error caused by the corrupted card) - and that taking out the battery for a few minutes just caused the memory to clear. I think I will try replacing that SD card reader as it seems to me like the component that's closest to the SD card (it's also a much cheaper part than the main board which would be my next choice). If the reader is faulty maybe it overheats as well.
03-10-2020 12:53 PM
